UK-POLOS.NET - THE VW Polo Forum • warning light came on today
Posted: Tue Jun 15, 2021 6:21 pm
by grazuncle2
Hi..
I went out for the day... a good hour trip -motorway mostly.
Parked up for 5 hours came back and started return journey.. after descending a long steep winding road.. (third gear and still braking hard-ish) then after a little time I noticed the very small orange triangle at the base of the cluster, with exclamation mark in it, light up. Checked hand brake, temp etc and nothing.. it went off before I could find a place to pull over. Carried on with my journey as normal. No sign of it since.
Checking the book it says if the light comes on take note of the message displayed in the instrument cluster.
The display never changed from live fuel consumption all the while I was driving.. ideas?
I'd take it in If I had to but as a previous lift engineer I know what intermittent logic faults are like and at £70 a pop at VW for diagnostic tests(I heard this figure a few times) I'm not confident.
Thoughts? common?
Re: warning light came on today
Posted: Tue Jun 15, 2021 6:45 pm
by SRGTD
Not had it on my car.
Manual refers to a red or yellow triangle enclosing an exclamation mark, rather than an orange one (page 23). Was (or is) a message displayed on the infotainment screen under the car settings - vehicle status screen? If not, then a fault code may have been stored by the car. If you know someone with VCDS or similar scan tool, they would be able to scan your car to get details of any fault codes as I suspect that’s all the dealer would do for the £70 diagnostic charge.
Posted: Tue Jun 15, 2021 8:49 pm
by grazuncle2
Thanks SRGTD
Ok.. yellow LOL
No messages and I did look :) I presume i could get VCDS (access to the history) for less that £70? I need advice on this.. I'm OK at learning new stuff if pointed in the right direction.
Thanks for replying
Posted: Tue Jun 15, 2021 9:36 pm
by Harrihealey02
You said it was a steep winding road you were travelling down, this could have caused the water level in your screenwash tank to trigger the low level warning as this coincides with the yellow triangle you saw. When you levelled off the water level would have stabilised and stopped the low level warning. Check your screen wash and top up as necessary. If there’s no warning logged in the ecu which you can scan with any cheap Bluetooth ECU device it should be nothing to worry about.
Posted: Tue Jun 15, 2021 10:10 pm
by SRGTD
As far as I know you only get a low washer fluid warning light if the car has the optional winter pack, so unless the OP’s car has this option (heated front seats and low washer fluid warning light), it’s unlikely that low washer fluid level would have triggered a ‘priority 2’ warning.
Posted: Tue Jun 15, 2021 10:24 pm
by grazuncle2
Thanks for taking an interest.
I'd gladly get a scanner of some description if someone can point me in the right direction, please?
Thanks all.
Posted: Wed Jun 16, 2021 7:37 am
by Stuart_Rendall
grazuncle2 wrote: Tue Jun 15, 2021 10:24 pm Thanks for taking an interest.
Thanks all.
Just any OBD scanner with Blutooth on ebay, amazon, or at a local hardware store will do. No need to spend anymore than £10. They all do pretty much the same thing. Or you can use OBD Eleven which is more indepth with coding etc.
Posted: Wed Jun 16, 2021 3:46 pm
by RUM4MO
Stuart_Rendall wrote: Wed Jun 16, 2021 7:37 am Just any OBD scanner with Blutooth on ebay, amazon, or at a local hardware store will do. No need to spend anymore than £10. They all do pretty much the same thing. Or you can use OBD Eleven which is more indepth with coding etc.
Hum, seeing would be believing, typical generic OBD2 scan tools will normally only reveal emissions fault codes, this one could be another VW Group specific non emissions fault code so money and time wasted.
Posted: Fri Jun 18, 2021 2:24 pm
by grazuncle2
Just a thought crossed my mind..
the warning light was not in the engine symbol... a warning triangle.
an OBDII scanner.. basic only.. will just tell me if there is an engine fault.. or am i barking up the wrong tree.. LOL
Are the triangle codes for other things than engine faults.. I'm out of my depth here
Posted: Fri Jun 18, 2021 3:13 pm
by RUM4MO
Like I said, a basic OBD2 scan tool will only reveal any of the mandated universal emissions related fault codes across all the modern marques of cars, that is what the initial requirement was for these OBD2 codes.
Posted: Fri Jun 18, 2021 3:47 pm
by Andy Beats
grazuncle2 wrote: Fri Jun 18, 2021 2:24 pm Just a thought crossed my mind..
Look here
viewtopic.php?f=71&t=73398
To find out what the triangle is warning you about, press CAR on the big screen above the gear lever and then press VEHICLE STATUS
IMO buying an OBD scanner for this is completely unnecessary.
Posted: Fri Jun 18, 2021 3:51 pm
by grazuncle2
I'll be certain to try that out..!
Thank you replying
Posted: Sat Jun 19, 2021 2:39 am
by Harrihealey02
I use an obd2 scanner, it’s made by a company called Carly. It’s designed to work on VW specific codes and has found some which the plug and play generic obd2 scan tool which I have couldn’t see. May be worth a look? https://www.mycarly.com/plan/?c=GB&b=vag&n=Volkswagen
It’s pricey at £93.89, but May be worth it. You can also code your car with it.
Posted: Sat Jun 19, 2021 9:40 am
by grazuncle2
Thanks for the link..
I did try what Andy Beats mentioned.. Vehicle Status
There were no messages or warnings there...
Whatever it was I am no wiser. I'll have to keep an eye on this
Posted: Sat Jun 19, 2021 12:49 pm
by Harrihealey02
Usually if the warning light disappears it means the fault it recognised has resolved itself and it isn’t a high priority one that will need a reset. You’ve got the right idea, monitor it and see if it comes again. The fact it wasn’t a red triangle is a good sign it’s not something very important.
