Page 8 of 9
Re: Giannis20vt's Polo 6c 1.0MPI
Posted: Wed Apr 12, 2023 9:11 am
by ciclo
Many of us are not interested in knowing where the forum users live...
Four languages are officially spoken in Switzerland
, only one in this forum.
Posted: Wed Apr 12, 2023 10:51 am
by Maarten
AFAIK Iichel is in the Netherlands (mostly)
Posted: Wed Apr 12, 2023 12:54 pm
by ndc78
Hola Ciclo, it is already clear to me that this forum is about exchanging various adjustments to the polo 6r. Which I follow a lot. Especially a lot of reports from you, very detailed and with pictures or videos. Simply great! I only wrote iichel because he is from my area. That we might meet up sometime. He also made a lot of adjustments to his Polo.
Posted: Wed Apr 12, 2023 1:24 pm
by ciclo
I can't do anything as an individual to fix the world, however, as a forum moderator, I have an obligation or at least must try to protect the interests of users, such as personal data.
Please try to process this data by private message (when possible for you). Thank you!!
Writing in English in the forum is not debatable.
My intentions were good at all times... have a happy day all of you... within what we are allowed.
Posted: Wed Apr 12, 2023 1:56 pm
by ndc78
i wanted to PM him, but I get the following message when I want to PM him: We are sorry, but you are not authorized to use this feature. You may have just registered here and may need to participate more in discussions to be able to use this feature.
Posted: Wed Apr 12, 2023 2:21 pm
by ciclo
The feature will be active forever when you have 10 forum posts. You only have three left.
Posted: Sat Apr 29, 2023 6:36 pm
by giannis20vt
Footwell lights + ambient lights simultaneously
I had a thought. When i finish the footwell installation to my Golf [link here
viewtopic.php?t=78237] i started thinking. I wanted to do the same think to my Polo
if there was a corresponding pin on the Polo BCM I could program it properly. I started searching and came across this topic.
https://wirer.sk/led_nohy/
This quy have done the same think. As a matter of act, his car had the same BCM with mine.
T46b/45 is the possible Pin for positive.
At the adaptation channel this pin represented by :
Leuchte10SHUTTER LRB45
It is for the XENON lights, i don't have such lights, so this is an opportunity.
I have already installed footwell lights. I have connected them to the ceiling light.
Lets get started
The right Pin for the T46b/45 position, is : 000 979 150 E
Negative to Ground.
I've come this far, programming and testing remains.
Posted: Sun Apr 30, 2023 5:16 am
by giannis20vt
2nd Part
Programming, or to say it more correctly, adaptation
So with the help of OBDeleven, and of course Miroslav's website instructions (remember the link I gave in my previous post)
Module 09 – Central Electronics
Security Access – 31347
Adaptations 10
we search for "LRB45"
This is the original state
the 1st thing we do is declare that Pin 45 from T46 is connected to an LED lamp
Leuchte10SHUTTER LRB45-Type_Of_Load_10 change to
allgemeineLEDmitOpenLoadDiagnoze
then
Leuchte10SHUTTER LRB45-Light_Function_A_10 change to
innenlicht
Leuchte10SHUTTER LRB45-Dimming_AB_10 change to
87 (this is the desired brightness value when a doors is open)
Leuchte10SHUTTER LRB45-Light_Function_D_10 change to
Terminal 58xs dimmer
Leuchte10SHUTTER LRB45-Dimming_CD_10 change to
7 (this is the desired brightness value when the lights is on)
This is the final state
Test:
https://www.youtube.com/shorts/j9yrc_N4CIM
Success, i am very pleased with the result.
I wonder if there is a way to adjust the brightness through the infotainment screen (with a virtual slide bar as is done in the case of the Golf)
I have a screenshot from OBDeleven, there are some alternative choices for the lightning.
Any thoughts ?
Posted: Sun Apr 30, 2023 12:52 pm
by iichel
Interesting, well done, firstly. Perhaps you can code it as a footwell light at the function field.
In the golf, you can control it because the BCM has a lot of ambient light options, sometimes even RGB. The polo 6C doesn't have this feature, so I really doubt you can have it in your radio.
Posted: Mon May 01, 2023 5:14 pm
by giannis20vt
I did some tests
Fussraumlicht (in English foot room light).
Works like the Innenlicht (the lights shine when one door opens)
Ambientelicht 1
Ambientelicht 2
Nothing works. I even tried to coding the module
Coding 07 – Long Coding Calculator
Byte 17 – Bit 0 Ambient lighting (from 0 to 1)
No result.
This guy
https://www.drive2.ru/l/479323024231760456 wrote that it worked when he coded like this:
Block 09 - closed area - coding - long coding -
Byte 17 - bit 0 - enable. Next: adaptation -
-Leuchte10SHUTTER LRB45-Dimming_AB_10 → 100
-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10 → 03
-Leuchte10SHUTTER LRB45-Light_Function_A_10 → Ambientchteli 1
-Leuchte10SHUTTER LRB45-Type_ Of_Load_10 → LED Kleinleistung ohne Open Load Diagnose.
I don't know. I keep looking.
Posted: Wed May 03, 2023 5:58 pm
by giannis20vt
i have a question about the adaptation for the light beams.
My car has Standard lights bulbs for the Low bean
Recently i changed the Halogen bulbs with LED bulbs.
I didn't do any adaptation and i don't have any faults.
Do i have to do the adaptation for LED lights in order to have better brightness ?
for example:
Leuchte6ABL LB44 those are my adaptation list for the left low bean.
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6 100
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6 0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6 maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6 maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6 maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6 0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6 0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6 1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6 36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6 Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6 Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6 not active
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6 not active
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6 not active
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6 not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6 not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6 not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6 not active
ENG124867-ENG115110-Leuchte6ABL LB44-Type_Of_Load_6 Xenon Abblendlicht
Should i change the "Type_Of_Load_6" from XENON Abblendlicht to "allgemeine LED" ? [lasttyp]
And the Dimming_AB_6 from 100 to 127 ?
Has this adaptation more brightness from the original one ?
Posted: Wed May 03, 2023 6:55 pm
by iichel
yes, exactly as you describe, that's fine. sometimes it takes some experimenting to see what type of load you exactly need. but looks OK to me.
setting dimming to 127 can prevent flickering of your LED lights.
Posted: Thu May 04, 2023 6:29 am
by giannis20vt
iichel wrote: ↑Wed May 03, 2023 6:55 pm
Thank you for the reply.
As a question, I have the following.
When someone has a setting for a halogen lamp and puts in an LED lamp without changing the adaptation, will he get less intensity in the lighting than if he makes the setting for an LED lamp and dimming at 127?
Posted: Sat May 13, 2023 6:25 pm
by giannis20vt
Today i did the back passengers footwell lighting.
I bought a small LED strip for this purpose , it was more convenient and easy at the installation.
I don't have much to say, for the wiring I preferred to remove the seats.
Posted: Sat May 27, 2023 5:42 pm
by giannis20vt
The infotainment system has been changed
From the 6C0035888B (composition touch)
To the 6C0035869F (composition color)
Of course with the help of the Online GECO connection.
Same "type" of hardware (one unit), all other alternatives require 2 units, one in the glove box and one in the center console.
Small differences, the most visible is the color screen for the Composition Color.
And the autoscan.
Saturday,27,May,2023,19:19:31:16365
VCDS Version: 22.10.0.1 HEX-V2 CB: 0.4622.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY308378 License Plate: KIK3090
Mileage: 66493km-41316mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378 Mileage: 66493km-41316miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000 CVN: DA6EEF6D
Coding: 01110012020400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AA_VW26.rod
VCID: 6597B189C5E238F3784-8030
VINID: 9E69EAAAA1A2A97A430080C720BAB66964
Readiness: 0000 0000
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08512057160424
Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
Shop #: WSC 49716 005 1048576
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 372B2BC12FCE7A631A8-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 C HW: 6C0 820 045 C
Component: AC Manuell H03 0202
Serial number: 1605161B-0418
Coding: 200000000000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1F1BE361A73E2223F28-804A
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-090-V1.clb
Part No SW: 6C0 937 090 E HW: 6C0 937 090
Component: BCM PQ26 HiKR H10 0101
Serial number: 006738042497
Coding: 000008404053005B4F844000400703000001580051010000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCMA0 006004
ROD: EV_BCMA0_006_VW26.rod
VCID: 2A0D02B5EC7CD78B956-807E
Driver door control module:
Subsystem 1 - Part No SW: 6R0 959 801 DG HW: 6R0 959 801 DG Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU012051661335260
Coding: 0000A0
Front passenger door control module:
Subsystem 2 - Part No SW: 6R0 959 802 DL HW: 6R0 959 802 DL Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU030041661212448
Coding: 1000A0
Subsystem 3 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU028041661198823
Coding: 0000A0
Subsystem 4 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU002051661233279
Coding: 1000A0
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00A 002 0380
Revision: -------- Serial number: 003TH006KLNX
Coding: 88C0C000000000005C000000000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2D32F51CDC670BE56-806E
Subsystem 1 - Part No SW: ----------- HW: 410 820 305 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00A520BDDD2520R
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 410 821 104 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A5209A1C310AF
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1FACC94822/
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12060D61520W
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 740 C HW: 6C0 920 740 C
Component: KOMBI 201 1420
Coding: 070409002100000811082A000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 221DEA95944C0FCBDD6-8076
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 090
Component: GW MQB A0 H10 0101
Revision: -------- Serial number: 006738042497
Coding: 01010008200A640071000000000000000001010000000000000000000000
Shop #: WSC 12345 123 12345
GVL: 01403C0000000000400000000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2615F685F864F3EBB1E-8072
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT X03 X014
Serial number: 13/11/2013 PV000031
Coding: 2C0000
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: PG5Q1139
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6D87C9A91D1200B3304-8038
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 869 F HW: 6C0 035 869 F
Component: MU-E--ER 050 7064
Serial number: 10061600012129
Coding: 026200003C00000041110001010000001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2E050EA5D094BBAB49E-807A
End----------(Elapsed Time: 00:36, VBatt start/end: 12.3V/12.3V)-----------
I kept the same coding. No errors, after some adaptations.
From ODBeleven
It says there is a new software. Any suggestions about that ? Where can I find the software update?
