UK-POLOS.NET - THE VW Polo Forum • Giannis20vt's Polo 6c 1.0MPI
Page 1 of 14
Posted: Mon Jul 12, 2021 3:57 pm
by giannis20vt
Hello everyone.
My name is Giannis, i live in Greece and one of my hobbies is cars.
Recently i bought a Polo for my wife. I love it and i would like to do some retrofits on it.
Although i have made some questions on other topics, i thought that is better to start one for my car.
Let's start from the basics
Autoscan from Vcds
VCDS Version: 20.4.2.0
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY--------   License Plate: POLO
Mileage: 62505km-38838mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378   Mileage: 62505km-38838miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AB    HW: 04E 907 309 CB
   Component: R3 1.0l MPI   H20 2496
   Revision: 33H20000
   Coding: 01110012020400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
   ROD: EV_ECM10MPI01104C906057AB.rod
   VCID: 65C104936461CFAE80-8030
Readiness: 0000 0000
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08512057160424
   Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 377D9EDB8E4D8D3EE2-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
   Component: AC Manuell    H03 0202
   Serial number:  1605161B-0418
   Coding: 200000000000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1F4D567B06BDD57E0A-804A
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 6C0 937 087 C    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H08 0087
   Serial number: 006088052444
   Coding: 000008404053005B4F844000400703000000580051010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   VCID: 2E53BBBF71174CF6B1-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU012051661335260
   Coding: 0000A0
   Front Passengers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU030041661212448
   Coding: 1000A0
   Drivers Door Rear Control Module:
   Subsystem 3 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU028041661198823
   Coding: 0000A0
   Passengers Rear Door Control Module:
   Subsystem 4 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU002051661233279
   Coding: 1000A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00A 002 0380
   Revision: --------    Serial number: 003TH006KLNX
   Coding: 88C0C000000000005C000000000800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A7B87EFBD5F90561D-806E
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 410 820 305 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A520BDDD2520R
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 410 821 104 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A5209A1C310AF
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 442 152 204 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AF1FACC94822/
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 442 152 204 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C12060D61520W
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 6C0 920 730 G    HW: 6C0 920 730 G
   Component: KOMBI         101 1420
   Coding: 0720090021000008010808000000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2541449324E10FAE40-8070
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 087
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006088052444
   Coding: 01000008200A640071000000000000000001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
1 Fault Found:
197175 - Control unit for battery monitoring
          U1050 00 [008] - No Communication
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 124
                    Mileage: 62401 km
                    Date: 2021.06.22
                    Time: 09:45:12
                    Supply voltage: Terminal 30: 13.7 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: PG5Q1139
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6DD17CB3BC91F7EEC8-8038
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 888 B    HW: 6C0 035 888 B
   Component: MU-E--ER      851 6490
   Serial number: 19041600012060
   Coding: 026200003C00000041110001010000001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2B55B2AB420539DE96-807E
First issue: Library of BCM is missing at VCDS. I have to find a solution, maybe someone has it in the vcds folder at his computer.
I would like to retrofit:
1. Trip computer (already bought the property stalks)
2. Puddle lights at doors
3. Footwell light at passenger and driver side
4. Light at grovebox
and many more....
I already order a used BCM 6C0-937-089-D in order to retrofit MFSW in the future...
Any advice and help is welcome
Re: Giannis20vt's Polo 6c 1.0MPI
Posted: Tue Jul 13, 2021 4:38 pm
by giannis20vt
A small teaser....
Image glovebox light
Image Image Image trip computer stalks and wiring
Image door puddle lights
Image Image dynamic turn mirror lights
Posted: Wed Jul 14, 2021 12:12 pm
by giannis20vt
1rst issue:
missing library of BCM for 6C. Is there anyone how has it on his Vcds folder to share it with me ?
It is critical for my, in order to continue with the BCM swap, and BCM settings (long coding)
Thank you in advance for your help.
Posted: Fri Jul 16, 2021 12:47 pm
by iichel
perhaps the easiest way is to obtain a real hex v2 enthousiast, with 3 VIN license
Posted: Sun Jul 18, 2021 6:34 pm
by giannis20vt
iichel wrote: Fri Jul 16, 2021 12:47 pm perhaps the easiest way is to obtain a real hex v2 enthousiast, with 3 VIN license
yes probably you are right.
Meanwhile i install the newest official release, even there i couldn't find that kind of library.
I will try though a friend that has the original real cable to see what i will get.
Posted: Fri Aug 06, 2021 6:00 pm
by giannis20vt
Today i started the conversion for MFD
Removed the steering wheel, replaced the stalks, putted new wires to the connector of the stalks. Also i putted new wires to the clock spring for MFSW.
The schematic for my car is this: (thanks iichel)
Image Image Image
The contacts are all MQS (micro quadlock system).
Everything were fine.
Now i have to connect the other side of my new wires to the connector of the BCM.
The stupid question is how am i going to do this in such a small place. I removed the BCM but still the space is so little.
Posted: Sat Aug 07, 2021 5:02 pm
by giannis20vt
OK searching on the net i found a picture of a guy laying down on the floor of his Polo. First he had removed the front seat !!!
So i did the same.
I finished with the wiring. I tested if the new buttons of the stalks. They are not working, nothing happened to the cluster display. So i have to search for activation. Probably a bit on the BCM module has to be activated or something like that.
Right now any help is welcome
Posted: Sat Aug 14, 2021 1:09 pm
by majk999
Hi
I've got the same problem
Wiring is ok, stalks not working. I think that problem is in IC. Mine is basic one..
Maybe there is someone at forum with basic IC and can show us coding from vcds
Posted: Thu Aug 19, 2021 3:59 pm
by giannis20vt
Finally, today i found time and i activated the DIS
17-Instruments
Coding 07
LongCodingHelper
Byte 1
Bit 2 [v] Driver Information System (DIS) active
DoIt
See picture, for more information.
And a short video
Posted: Sat Oct 09, 2021 3:37 pm
by giannis20vt
Well, today i made the 1rst attempt to swap the BCM
The swap was an easy process. But i failed to the coding process.
A lot of errors and warning messages.
Image Image
The translation of the Radio message from Greek to English is: The component protection is active !
I plugged the VCDS and started the scanning
Errors and more errors.
I found out that the Transport Mode was active, so i de-activated it. I managed to fix some errors, but not all of them. The most common is the
"15360512 - Component Protection"
This is the full scan log after the BCM swap.
Saturday,09,October,2021,16:42:01:00009
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY308378   License Plate: QQ
Mileage: 63608km-39524mi   Repair Order:
Scan: 01 02 03 08 09 15 17 19 44 5F 69
VIN: WVWZZZ6RZGY308378   Mileage: 63608km-39524miles
02-Auto Trans -- Status: Cannot be reached 0100
69-Trailer -- Status: Cannot be reached 0100
   Revision: 33H20000
   VCID: 65C104936461CFA350-8030
Address 02: Auto Trans
Cannot be reached
   VCID: 377D9EDB8E4D8D3332-8062
   VCID: 1F4D567B06BDD573DA-804A
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0094
   Serial number: 006588036166
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 3169A0C3602953037C-8064
   Driver door control module:
   Coding: 0000A0
   Front passenger door control module:
   Coding: 1000A0
   Coding: 0000A0
   Coding: 1000A0
1 Fault Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:33:01
   VCID: 3A7B87EFBD5F905BCD-806E
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
1 Fault Found:
          U1101 00 [137] - Active
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:28:55
   Coding: 0704090021000008110808000000000000000000
   VCID: 2541449324E10FA390-8070
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:29:34
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006588036166
   VCID: 2643439F59E704BB99-8072
4 Faults Found:
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [009] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:27:49
                    Terminal 30 power supply: 11.8 V
                    Terminal 15: On
131703 - No Communication with Transmission Control Module
          U0101 00 [009] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:27:49
                    Terminal 15: On
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:27:49
                    Terminal 15: On
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:27:49
                    Terminal 15: On
   Coding: 000700
   VCID: 6DD17CB3BC91F7E318-8038
   VCID: 2B55B2AB420539D346-807E
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 199
                    Mileage: 63608 km
                    Date: 2021.10.06
                    Time: 16:18:59
                    Voltage terminal 30: 12.0 V
Address 69: Trailer
Cannot be reached
End-------------------------(Elapsed Time: 02:38)--------------------------
I putted back my original BCM, clear the codes, and Thank God, everything was come back to normal.
So what should i do ?
Posted: Sat Oct 09, 2021 8:15 pm
by Kr1s
Really good guide for you here. You need to copy the coding from your old BCM to the new one.
https://www.team-bhp.com/forum/diy-do-y ... odule.html
Posted: Sun Oct 10, 2021 4:46 am
by giannis20vt
Kr1s wrote: Sat Oct 09, 2021 8:15 pm Really good guide for you here. You need to copy the coding from your old BCM to the new one.
Hi my friend, thank you for your answer.
I did, i copied the old coding to the new BCM.
I think the component protection (CP), requires on line connection with the VW servers. So it's a thing that only an registered VW agent can solve.
Posted: Wed Dec 29, 2021 6:39 am
by giannis20vt
Finally, after a long time i managed to visit a VW "specialist" to swap the cluster and the BCM
We swapped both Cluster and BCM at the same time, and after a lot of tries and time we didn't managed to successfully swap those 2 components. We remove the new BCM and install the old one, and finally had some progress.
A long story sort we did the cluster swap. I had the 6c920730G and now i have the 6C0920740C. It seems to working fine. ( i have some errors with VCDS but is it working.)
I have a problem and i want your help please.
The remote locks are not working. I can lock and unlock the doors only with the key not with the buttons. So how can i pair my keys ? (i have the original BCM on my car)
Posted: Thu Dec 30, 2021 9:58 am
by giannis20vt
Today i discovered that the (09) Cent.Elect had the Transporter Mode Active !!! (i don't know why)
So i went into 09 Central Electronics, under adaptions - changed transport mode to "not active". I also had to put in the security code before doing this.
But the problem not solved :cry: The remote lock doesn't work with either key. Any idea?
Posted: Sun Jan 02, 2022 4:57 am
by giannis20vt
Did anyone come up with an idea?
Is there any suggestion?
