Instrument cluster-Help
scotspie501
Drives: 2002
Post by scotspie501 »
Hi All
My son has a polo 2002 9N,I had a code that advised cluster was faulty but needed to get part number ,so tried to strip it and when rebuilding all lights were dead and car wouldnt start
it would crank ,the left hand plug seemed loose so I found one in breaker yard fitted it and lights came on and cranked but came up with code immobiliser locked car out due to wrong key
Can you fit any Instrument cluster
My sons is 6Q0920900H B41
Breaker one is 6Q0920900H VO3
is the breaker one faulty
scotspie501
Drives: 2002
Re: Instrument cluster-Update
Hi All
Decided to strip old one out and suspected dry join ,sure enough ordered Soldering kit as my gas one is,nt that good stripped today and resoldered the loose plug
all going will find a company that will program the new instrument cluster
phew what a weekend
