Intake valve cleaning
Posted: Tue Oct 19, 2021 8:30 am
by Cro_vw
just wondering if any of you guys driving 1.0 tsi with higher milage, did you have any sort of problems with dirty valves? Since it is direct injection I'm wondering now at 30 000 km's how dirty my valves are, and thinking about some cleaner to spray it, since nothing else would work!
I asked in dealership about that, they said we don't do that in warranty unless car starts to have issues, like using more fuel, rough idle etc.
I know the best way is to walnut shell blasting intake valves, but I don't know anyone doing that.
Re: Intake valve cleaning
Posted: Tue Oct 19, 2021 2:44 pm
by OomStu_ZA
My vehicle started "fish hooking" at about 50 000 KM's so took it back to the dealership in limp mode. They ran some type of diagnostic then confirmed cylinder 1 injector was the cause. They did further work on it thereafter and all has been reasonably fine since. The whole process cost me about 45min/1hr of my day.
Not sure if it was carbon build up related but it is in the same neck of the woods so asked one of the technicians about carbon build up (on EA888) and he said it shouldn't be an issue until around 100 000KM's. What do I know so had to take his word for it and am not too concerend since I usually trade my vehicle in every 3 - 4 years (60 000KM - 90 000KM).
Although you have the 1.0L engine this video by Humblemechanic will illustrate what it looks like inside the engine, a 2.0L Golf, after 10 000 miles (±16 000 KM's):
https://youtu.be/CB5ThYfX7ag
Posted: Wed Oct 20, 2021 7:12 am
by Cro_vw
Yeah I've seen that video, I'll definitely put some fuel additive today, datacol or luqi molly to clean tips of injectors. And I think at 100 000 km there would be a lot of carbon build up on injectors and valves.
I'll try to clean it myself, take intake manifold down, and use cleaner. I don't belive any mechanic will do it properly.
Very stupid design, they could have added another port injector, just to clean valves, this will be pain in the ass :x :x
Posted: Wed Oct 20, 2021 1:39 pm
by monkeyhanger
Not a bother on the GTI engine as that does have port injectors to wash the backs of the valves with petrol vapour.
Posted: Wed Oct 20, 2021 1:43 pm
by OomStu_ZA
monkeyhanger wrote: Wed Oct 20, 2021 1:39 pm Not a bother on the GTI engine as that does have port injectors to wash the backs of the valves with petrol vapour.
Now I'm torn becuase the mechanic said it didn't have port injectors to wash the backs of the valves but there we go I guess... Vehicle still under warranty so if it occurs again still not my problem :) except I'll have to change my name to Carlos while the vehicle is with VW.
Posted: Wed Oct 20, 2021 6:32 pm
by monkeyhanger
OomStu_ZA wrote: Wed Oct 20, 2021 1:43 pm
Golf GTI EA888 3 engine doesn't, Polo GTI EA888 3b does.
The Polo GTI engine has intake from Audi-valvelift tech with both port and direct injection for Budack cycle lean running under low load.
Posted: Wed Oct 20, 2021 7:37 pm
by Cro_vw
I work at car parts store I'll check tomorrow if GTI has port injection in partslink, I know for sure Polo 3cly doesn't have port injection, and there will be valve cleaning sooner or later
Posted: Wed Oct 20, 2021 8:05 pm
by SRGTD
Cro_vw wrote: Wed Oct 20, 2021 7:37 pm I work at car parts store I'll check tomorrow if GTI has port injection in partslink, I know for sure Polo 3cly doesn't have port injection, and there will be valve cleaning sooner or later
Whether or not the GTI / GTI+ continued to have port injection when it became WLTP compliant was discussed back in early 2019 in the ‘New GTI+ and delivery’ discussion thread.
Check out the pictures that were posted by forum members @monkeyhanger and @peter007 on page 120 of that discussion thread at the link below. The pictures show that both the pre-WLTP and post-WLTP GTI engines have a port injector fuel rail, port injector loom connector and fuel pressure sensor.
https://www.uk-polos.net/viewtopic.php? ... start=1785
Posted: Wed Oct 20, 2021 8:50 pm
by Dark_cze
SRGTD wrote: Wed Oct 20, 2021 8:05 pm Whether or not the GTI / GTI+ continued to have port injection when it became WLTP compliant was discussed back in early 2019 in the ‘New GTI+ and delivery’ discussion thread.
One of the reasons why I choose Polo and not Golf :D I think reason why Polo have it is mostly because of budack cycle. We are running EA888 gen3 B while Golf have (at least mk7/7.5 had) non B version.
