engine swap
Posted: Fri Oct 22, 2021 6:10 pm
by Mejenby
Hi, i need to swap engine in My GTI 2017 1.8tsi. does anyone know which engine i can use to combinded with mine, Audi a3, Audi a4 1.8tfsi 2.0tfsi? Passat 2.0 tfsi? year 2008 - 12. These engines är cheap here. Buuuut could i take One of these and move over turbo, manifold etc etc from mine? Or any ideas of which car i can use as engine donor?
Re: engine swap
Posted: Fri Oct 22, 2021 7:02 pm
by iichel
Do you need to replace a sick engine or do you like to upgrade to a more high performance engine?
Re: engine swap
Posted: Fri Oct 22, 2021 7:21 pm
by Mejenby
Broken engine
Re: engine swap
Posted: Fri Oct 22, 2021 7:27 pm
by Dink
the stock engine code is DAJ (i believe both manual and dsg are interchangeable) ea888 gen 3
the seat ibiza, audi a1 are the same engine. The issue with using one from a different car is it may use a different gearbox so your stock gearbox won't fit (polo uses 02M equivalent where the others probably use 02Q)
crank walk on the original engine?
Re: engine swap
Posted: Fri Oct 22, 2021 7:38 pm
by Mejenby
Car decide to go off road and wanted to stand on a big rock exactly under the engine. Havent looked at the car so much yet, but thinked just in case which car i can take engine from. Sadly Ibiza and a1 isnt that cheap as the passat, a3, a4 with 1.8tfsi or 2.0 tfsi.
Re: engine swap
Posted: Fri Oct 22, 2021 7:39 pm
by Mejenby
Pics
Re: engine swap
Posted: Fri Oct 22, 2021 7:47 pm
by Mejenby
Re: engine swap
Posted: Fri Oct 22, 2021 7:48 pm
by Dink
Mejenby wrote: Fri Oct 22, 2021 7:38 pm Car decide to go off road and wanted to stand on a big rock exactly under the engine. Havent looked at the car so much yet, but thinked just in case which car i can take engine from. Sadly Ibiza and a1 isnt that cheap as the passat, a3, a4 with 1.8tfsi or 2.0 tfsi.
they will probably be the types of cars with different gearbox which may fit but then the drive shafts may not fit.
i would of thought that there isn't much difference in the engine price ?
Re: engine swap
Posted: Sun Sep 24, 2023 5:22 am
by Mejenby
The engine is fine but i need a new gearbox. I have googled my eyes sore. What gearbox is the 6 speeed manual? Code? Type? Etc and which cars can i take a gearbox from?
Re: engine swap
Posted: Sun Sep 24, 2023 7:56 am
by Maarten
Code of gearbox should be in your manual
First page sticker, or in the boot next to your sparewheel
Re: engine swap
Posted: Sun Sep 24, 2023 1:12 pm
by Bepis
The manual gearbox code in mine is QQR, which is an 0A8 MQ350. From my own research for other things like short shifters and diffs the 0A8 is apparently somewhat different to the other gearboxes in the MQ350 family but what those differences are I don't know.
https://blog.fcpeuro.com/definitive-gui ... 2m-02q-0fb
Re: engine swap
Posted: Mon Sep 25, 2023 2:12 pm
by Mejenby
Does anyone know if the NJU box fits. half the price of a NJU against QQR. Look exactly the same.
Re: engine swap
Posted: Mon Sep 25, 2023 3:33 pm
by iichel
I know the QQR transmission is physically smaller, to fit the Polo engine bay in, comparison to other MQ350 gearboxes
Re: engine swap
Posted: Mon Sep 25, 2023 5:53 pm
by Mejenby
NJU is the gearbox from polo gt blue 1.4 140hp 250nm
Re: engine swap
Posted: Mon Sep 25, 2023 8:07 pm
by Bepis
Seems it's the same housing but different gear ratios
