Hi all
I tried to check the engine oil on my sons 9n polo
but the dipstick was tight to push back in
I tried it a couple of times but very tight
has anyone else come across this
tight dipstick
- Drives: 2002
Re: tight dipstick
No, there's not really anything in the stick or the tube to cause that. Where does it bind?
Re: tight dipstick
I'd think that the design of the dipstick means that it would "prefer" to to fitted only in a couple of orientations.
If it is only stick at the final 1/2" maybe the rubber sealing ring at the top is now harden with age.
Also, does this dipstick look like it is a genuine VW Group part?
Maybe someone was replaced the final plastic extension section with an aftermarket version.
