MSFW for skoda rapid india(PQ)
Forum to discuss the Skoda Fabia
vaskar
Drives: Skoda rapid
Post by vaskar »
i have skoda rapid rider 2020(india) petrol 10. TSI. Its a PQ25 car.
My current instrument cluster is: 5J5920860H
BCM: 7E0937089D
Steering control : 1S2909144P
I am planning buy steering wheel with part no "3V0 419 091 L CWE"
1. Will this fit my car?
2. Also since i dont have MSFW in my car. I believe i will need harness.
Will airbag/steering harness "5JA971584" go with "3V0 419 091 L CWE".?
Current Steering
Current Steering
current steering.jpg (325.07 KiB) Viewed 63987 times
Proposed steering
Proposed steering
3V0 419 091l CWE.jpg (422.38 KiB) Viewed 63987 times
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Re: MSFW for skoda rapid india(PQ)
Post by exantas »
I am not an expert on the subject but I don't believe that those buttons are going to work for you.
Steering wheel will fit physically, but the button wont work cause they are from Suberb III (3V0).
When it comes to PQ25 and MFSW I would recommend you sticking with buttons ppl have tried before.
I have a list with the tested buttons an old post of mine
viewtopic.php?p=561978#p561978
I general you need to look for steering wheels with code 3T0 (Suberb II facelift)
airbag/steering harness you say, I believe it should work, provided you install the 2 missing cables at T41 connector
viewtopic.php?t=54171
vaskar
Drives: Skoda rapid
Post by vaskar »
Thank you
I also figured i will need either 5E0919719E or 5E0919719F for switches
skoda_indian
Drives: Rapid PQ25
Post by skoda_indian »
Hey Vaskar, I am also doing the same upgrade on my Skoda Rapid TSI Rider and have some info. Please let me know how can we get in touch.
Shefan4141
Drives: Rapid
Post by Shefan4141 »
Hi @Skoda_indian, I followed your threads and happy to know that you were able to successfully installed a MSFW steering wheel to your rapid rider. I am in same situation now, need your help with the steering, buttons and wiring to get the MSFW Installed on my Rapid rider 2020.
As you know Indian market is brutal and charging a bomb for the parts and services. If you opt to get steering on your own they won't help.
If you don't mind can you help me with your contact? Thanks
My Instagram id: fattyacid_yearone.
Hope you to get your response. Thanks
