We have been made aware that users have been having difficulty signing up, and notification emails haven't been received. This has now been resolved and there should be no problems for anyone going forward. Our apologies - last minute firewall upgrade with a missing rule!
The UK-Polos.NET Team
1988 1.4cl auto keeps cutting out while driving
Lofty George
Drives: 1998 1.4 cl auto
Post by Lofty George »
Hi. I have searched the net and not really found a straight answer. There seems to be lots of posts about this issue. I have replaced the throttle body which cured the problem for about 3 days now its gone back to stalling at least 6 times on the 20 min drive to work. It also doesn't get up to temperature staying well velow 70° not sure if the problems are connected.
Thanks in advance.....I'm desperate...its bloody cold on the motorbike 🏍
JUUL
Drives: 6N 1995
Re: 1988 1.4cl auto keeps cutting out while driving
Post by JUUL »
Temperature = faulty thermostat.
Power loss = EGR (lines or valve) and crankcase breather (lines or valve) can be clogged. Did you clean these out as well? These are the first issues I can think of because they are very common. It can also be due to a dirty fuel filter or coil/sparkplugs for example.
MisterBoo
Drives: Polo coupe 1987
Post by MisterBoo »
Have you sorted this yet? If not, could it be that the coil is old and not giving a good spark when it heats up? Test for a spark when it cuts out. Use a timing light strobe if you have one.
