Hello, strange one this! Car is 2007 1.2.
My electric power steering pump makes a whining noise but only when the lights are on???????
It’s definitely the pump as the noise comes directly from the pump itself and when I move the steering wheel the pump is quiet when working but noisy in its rest state.
I kind of get that pumps can get noisy but it the fact this only happens with the lights on?
Thanks, Tom.
Electric power steering whining
Re: Electric power steering whining
Well the mystery continues, the noise is actually coming from the headlamp unit, looks like it’s the headlight aim adjustment motor.
Also I’ve noticed a tapping noise coming from the headlamp on the other side!!! How on earth headlamps can cause so much trouble it a mystery!
So today I bit the bullet and took the bumper off and pulled off the headlamp that sounds like it has a woodpecker stuck inside it!
Mine are Hella units and a bit of research revealed the motors are sealed in the casing….great design!!! So I cut the casing open where the motor is but I couldn’t work out how it comes out, the motor spins freely so maybe it’s a fault with the electronics?
If anyone knows how to fix these units that would be great. I siliconed the case shut and put aluminium tape over the join.
Very frustrating morning!!!!
- 33A6B4D2-F393-498B-A1B5-4A05622F991C.jpeg (1.51 MiB) Viewed 909 times
- 6898EDC6-E153-4AEC-9728-9E011946847D.jpeg (1.88 MiB) Viewed 909 times
- A98A85C5-CED2-4AE5-B69F-66C9807C06CB.jpeg (1.51 MiB) Viewed 909 times
- CA87AA2C-1028-4C55-B7B7-A926C27A4EAA.jpeg (1.48 MiB) Viewed 909 times
