Page 1 of 3
Toymachine1' Polo 6R Comfortline 1.2 TSI
Posted: Thu Apr 28, 2022 7:03 pm
by Toymachine1
Hey,
Bought Polo 6R 2010 Comfortline early in 2022. Got quite obsessed with the car. Since then I have done a few retrofits and upgrades such as:
- replaced original plastic steering wheel with a Passat MFSW.
- installed Polo 6C gear lever with grey stitching. Super cool.
- Installed led bar behind front bottom mask (to keep OEM look, but be able to see. I have halogen OEM lights)
- installed steel pedals
- retrofitted a used GTI cluster (6R0920870B) to have MFD+. Got this one from Australia to Finland. Sent it again for a one guy to move Immo data and do all the EEPROM magic.
- Retrofitted 7P6035730J Bluetooth module with OEM mic which is installed in OEM location and everything. This worked all good with my RCD-510 BEFORE I installed the GTI cluster.
- Changed RCD-510 from Blaupunk to Bosch. The Bosch version shows song titles, has far less BT bugs and the biggest reason I got it to be able to retrofit RVC.
- Ordered door sills for some protection and looks
- Vinyl wrapped the center interior parts with brushed steel look. Searched for GTI interior parts for way to long and decided to take another route with changing the boring Comfortline look.
Fixes done (in addition to changing filters and oil...):
- Oil leak fixed in the oil filter housing. Needed new sealant.
- Front spring broke, changed both and other related parts (OEM was good enough)
- Battery died, upgraded to 80Ah (yes it does fit but needed to modify the car a bit.) This was urgency fix during Christmas Eve and it was only battery I found.
Pending jobs:
- Install Chinese RVC
- install front PDC's, wiring and change the module
- Vinyl wrap rest of the interior parts (light switch and side vents)
- change rear lights to something better looking, probably 6C OEM
- Change rear bumper, probably 6R GTI
- Find 17" GTI Polo OEM rims for summer season
- Some rust here and there, probably get the whole car painted
- Engine has 198000KM, running well and maintained well always, but if any bigger hiccups probably doing some upgrades on that end.
- Paint front break calibers
- tint rear windows
- Audi S1 or some better seats some day
I am doing things slowly and taking time to find used parts with a good bargain. This car seems to be a very good hobby and balances stressful work well. Last year when I first drove Polo I was very surprised how well it drives.
Re: Retrofitted bt-module and MFD+. Now frozen on MFD Phone menu.
Posted: Thu Apr 28, 2022 7:29 pm
by iichel
is BAP activated in radio and BT module?
Posted: Thu Apr 28, 2022 7:46 pm
by Toymachine1
Hey Iichel, appreciate your quick response. I am not seeing any bits related to BAP. Maybe those are undocumented in OBD11? Although not finding any bits related to those through fast googling. I will try to export some full report from the car by tomorrow.
Edit: according to quick research RCD 510 should always communicate using BAP?
Another edit: according to RossTech telephone retrofit guide my bt module should communicate using BAP
Posted: Thu Apr 28, 2022 7:58 pm
by iichel
The RNS510 had some BAP related stuff in byte 7 and some of the BT modules have some BAP stuff in the adaptation channels
Posted: Fri Apr 29, 2022 9:30 pm
by Toymachine1
Hey, I think I've pretty much confirmed that communications by all the parts should be using BAP. There are no settings to alter related to that on RCD or BT module. Also communication somewhat works as both RCD and info cluster can see the BT module.
Did a full scan of the car with OB11, maybe some hints here what could be wrong? Altered the scan to add some typos as I was stopped by forum spam filter
OBDeleven vehicle history log
Date: 2022-04-29 18:45
VIN: WVWZZZ6*********13
Car: Volkswagen Polo
Year: 2010
Body type: 5-dr hatchback
Engine: CBZB
Mileage: 190000 KM
Backup
Control unit: 01 Engine
System description: SIMOS10.20
Software number: 03F906070D
Software version: 9851
Hardware number: 03F906070D
Hardware version: H02
ODX name: EV_ECM12TFS02103F906070D
ODX version: 003015
Backup name: Engine
Long coding:
001900D6202400080000
Adaptations:
Idle RPM correction:
87
Activating and deactivating all development messages:
Development messages:
not active
Static maximum speed limit:
250.0 km/h
Individually adjustable maximum speed limit:
250.0 km/h
Activation of static maximum speed limit:
Off
Deactivation of static maximum speed limit:
Bytefield_Value:
0000
Advanced identification:
Program memory status:
Error in flash memory:
No
Flash memory faulty:
No
Communication error:
No
Flash memory not programmable:
No
Number of programming attempts:
5
5
3
Number of successful programming attempts:
5
3
3
Maximum number of possible update programming:
Number of possible flash attempts:
0
0
0
Coding length:
10
Workshop code and date of last update programming of SW module:
Year:
16
Month:
2
Day:
22
Device numer:
1048576
Importer nuber:
2
Dealership nuber:
1281
Programming status:
Correct result
Year:
16
Month:
2
Day:
22
Device nuber:
1048576
Importer nuber:
2
Dealership nuber:
1281
Programming status:
Correct result
Year:
16
Month:
2
Day:
22
Device nuber:
1048576
Importer nuber:
2
Dealership nuber:
1281
Programming status:
Correct result
FAZIT-identification:
Manufacture location index:
SJ8-FST
Day of manufacture:
25.01.10
Manufacturer- test stand nuber:
0013
Running manufacturer nuber:
0261
Manufacturer modification status:
Control module family:
Decoration variant:
Construction version:
Manufacture version:
Diagnostic mode:
VW - diagnostic mode
VW/Audi part nuber:
03F906070D
SoftwareVersion:
9851
Serial nuber:
Vehicle Identification Nuber (VIN):
WVWZZZ6RZ******13
Hardware part nuber:
03F906070D
System description:
SIMOS10.20���
Adaptation workshop code:
Device numer:
1048576
Importer nuber:
2
Dealership nmber:
1281
ASAM/ODX file identification:
ASAM/ODX file version:
003015
HardwareVersion:
H02
Coding workshop code:
Device nuber:
182020
Importer nuber:
768
Dealership nmber:
1
System abbreviation:
J623
Versions of software module:
9851
9851
9851
Engine code:
CBZB
Programmability status:
Programmability:
programmable
Program consistency:
Program present
Mileage: 190000 km
Date: 2022-04-29 16:21
Backup
Control unit: 03 Brakes
System description: ESP8.2i front
Software number: 6R0907379R
Software version: 0002
Hardware number: 6R0907379R
Hardware version: H04
Backup name: Brakes
Long coding:
210228E3217600B2842614E384D400401300
Adaptations:
Channel 001: 0
Channel 007: Secured
Channel 009: 0
Channel 010: Secured
Channel 051: 1
Channel 058: 1
Channel 073: 1
Channel 080: Secured
Channel 088: Secured
Channel 089: Secured
Channel 090: Secured
Channel 099: 0
Mileage: 190000 km
Backup
Control unit: 08 Air Conditioning
System description: Climatic
Software number: 6R0820045E
Software version: 0650
Hardware number: 6R0820045E
Hardware version: 24
Backup name: Air Conditioning
Adaptations:
Channel 003: 1
Mileage: 190000 km
Backup
Control unit: 09 Central Electrics
System description: BCM PQ25 H+4
Software number: 6R0937087D
Software version: 0207
Hardware number: 6R0937087D
Hardware version: H46
Serial numer: 0147 030101276
Backup name: Central Electrics
Long coding:
24B02BBF08A30000013006007E2B9FD000C0410F60840000200000000000
Subsystems:
Subsystem: RLS 030210 05
Long coding: 0005F3
Subsystem: J386__TSG_FT
Long coding: 08BC30
Subsystem: J387__TSG_BT
Long coding: 08BC30
Subsystem: J388__TSG_HL
Long coding: 08BC32
Subsystem: J389__TSG_HR
Long coding: 08BC32
Adaptations:
Channel 000: 0
Channel 001: 0
Channel 003: 0
Channel 004: 0
Channel 005: 0
Channel 006: 0
Channel 007: 0
Channel 008: 1
Channel 009: 0
Channel 010: 0
Channel 011: 1
Channel 012: 1
Channel 013: 0
Channel 014: 0
Channel 015: 0
Channel 020: 1
Channel 021: 1
Channel 022: 1
Channel 023: 1
Channel 024: 0
Channel 025: 0
Channel 026: 1
Channel 027: 0
Channel 028: 1
Channel 029: 1
Channel 030: 2
Channel 031: 0
Channel 032: 40
Channel 033: 80
Channel 034: 30
Channel 035: 2
Channel 036: 2
Channel 037: 80
Channel 038: 21
Channel 039: 15
Channel 040: 14
Channel 041: 20
Channel 042: 5
Channel 043: 4
Channel 044: 5
Channel 045: 100
Channel 046: 1
Channel 047: 15
Channel 048: 15
Channel 050: 0
Channel 051: 0
Channel 052: 0
Channel 099: 0
Mileage: 190000 km
Backup
Control unit: 10 Parking Assistance
System description: PARKHILFE 4K
Software number: 6R0919475
Software version: 0008
Hardware number: 6R0919475
Hardware version: H07
Serial number: 71391001521347
ODX name: EV_VW250ParkiAssis2
ODX version: S01006
Backup name: Parking Assistance
Long coding:
100001
Adaptations:
Speaker volume for rear park assist:
Stage 4
Speaker frequency for rear park assist:
Stage 4
Visual display for park assist:
OPS display
Audio reduction request:
On
Park assist activation tone:
On
Reset to factory setting:
Yes
No
No
No
No
1
1
1
1
1
1
Bootloader:
10000
Application:
10000
Data record:
10000
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
0
Day:
0
Programming status:
Correct result
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
0
Day:
0
Programming status:
Correct result
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
0
Day:
0
Programming status:
Correct result
Date of last coding:
Year:
0
Month:
0
Day:
0
ATW-001
Day of manufacture:
23.01.10
Manufacturer- test stand number:
P5AH
Running manufacturer number:
0097
Decoration variant:
Identification of standard software:
Standard software module:
BAP
Vendor:
Audi
Major Version:
1
Minor Version:
3
Revision:
1
UDS - protocol
Vendor:
not assigned yet
Major Version:
1
Minor Version:
2
Revision:
12
CAN - driver
Vendor:
Vector
Major Version:
1
Minor Version:
47
Revision:
0
ISO15765-2
Vendor:
not assigned yet
Major Version:
1
Minor Version:
2
Revision:
12
VW/Audi part number:
6R0919475
SoftwareVersion:
0008
Serial number:
71391001521347
Hardware part number:
6R0919475
System description:
PARKHILFE 4K
Device number:
0
Importer number:
0
Dealership number:
0
Date of last adaptation:
Year:
0
Month:
0
Day:
0
EV_VW250ParkiAssis2
S01006
HardwareVersion:
H07
Device number:
30
Importer number:
259
Dealership number:
124673
J446
version:
0003
version:
0008
version:
0009
Programmability:
programmable
Program present
Mileage: 190000 km
Backup
Control unit: 15 Airbag
System description: VW10Airbag008
Software number: 6R0959655C
Software version: 0018
Hardware number: 6R0959655C
Hardware version: H09
Serial number: 003DW00C0J0-
ODX name: EV_AirbaVW10BPAVW250
ODX version: A01001
Backup name: Airbag
Long coding:
003038
Adaptations:
Airbag adaptations:
Passenger airbag igniter:
activated
Driver airbag igniter:
activated
Front passenger side airbag igniter:
activated
Driver thorax airbag igniter:
activated
Reserved:
not defined
Igniter for battery interrupt:
not defined
Front passenger head curtain airbag igniter:
not defined
Driver head curtain airbag igniter:
not defined
Front passenger side seat belt tension igniter:
activated
Driver side seat belt tension igniter:
activated
Key switch:
Airbag deactivation key switch installed
Seat occupied recognition:
not defined
Reserved:
Reserved
Reserved:
Reserved
Reserved:
Reserved
Reserved:
Reserved
No
No
No
No
Counter:
0
Condition of counter:
valid
Counter:
0
valid
Counter:
0
valid
Counter:
0
valid
Number of parameterization attempts:
1
Number of successful parameterization attempts:
1
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Key switch:
Device number:
0
Importer number:
0
Dealership number:
0
Device number:
0
Importer number:
0
Dealership number:
0
Coding:
Coding:
003038
Coding:
12344
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Year:
10
Month:
2
Day:
9
BPA-00A
Day of manufacture:
25.01.10
15DW
C0J0
Identification of parameterization:
Version number:
Version number:
Version number:
01
Version number:
90
Version number:
09
Diagnostic mode:
6R0959655C
SoftwareVersion:
0018
Serial number:
003DW00C0J0-
Vehicle Identification Number (VIN):
WVWZZZ6RZ******13
6R0959655C
System description:
VW10Airbag008
Device number:
30
Importer number:
259
Dealership number:
124673
Parameter set part number:
v00301656R0
Parameter set version:
0001
A01001
HardwareVersion:
H09
Vehicle equipment code:
0000000000000001
Device number:
30
Importer number:
259
Dealership number:
124673
Parameterization workshop code:
Device number:
30
Importer number:
259
Dealership number:
124673
Parameterization date:
Year:
10
Month:
2
Day:
9
J234
0018
Installed condition documentation:
Hardware subassembly:
003
Hardware sorting key:
00DW
Software subassembly:
004
Software sorting key:
0008
Variant of software type:
Programmability:
not programmable
Program present
Consistency of EEPROM-data:
Data consistency:
valid EEPROM data
Error during last data record download:
no error
Data record modification:
Data record not changed
Parameterizability:
Parameterizable
Mileage: 190000 km
Backup
Control unit: 17 Dashboard
System description: KOMBI
Software number: 6R0920870B
Software version: 0605
Hardware number: 6R0920870B
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A04716
Backup name: Dashboard
Long coding:
140E00
Adaptations:
not active
Service-key settings:
p_write_delay_time:
40 s
p_write_delay_speed:
20 km/h
p_write_distance:
20 km
p_forcewrite_qual_time:
10 s
p_main_switch_keyless:
Off
p_main_switch_basis:
Off
Acoustics for timeout signaling:
All-wheel electronics:
Not available
Lock electronics:
Not available
Display depiction:
Display depiction:
Not available
Service_Key_Clear_All_Counters:
clear_all_counter:
Yes
velocity_detection:
Speed source:
Distance impulses
Distance impulses:
4
indicator_celebration:
Zelebrieren:
active
Distance:
Distance:
190000 km
WIV: Coding of Service Interval Extension (SIE):
Status ESI or SID:
ESI or SID on
Selection of ESI or SID:
Extended Service Intervals (ESI)
Oil level:
Oil level evaluation
oil pressure:
Dynamic oil pressure
Remote clock receiver:
Without remote clock receiver
Oil quality:
Poor oil quality
TOG:
Oil level thermal sensor connected to instrument cluster
WIV: Resetting ESI:
Reset
Language version:
English
Display correction of consumptions and operating range:
100 %
Seat belt warning:
Gurtwarnung:
Version 4
Hour:
16 h
Minute:
13 min
Display correction of fuel gauge:
Anzeigekorrektur Kraftstoffvorratsanzeige:
0.0
Speed threshold of dynamic oil pressure warning:
Offsetwert:
kein Offset
SIE: distance driven from inspection:
4900 km
SIE: time from inspection:
165 d
SIE: oil quality:
Poor oil quality
SIE: soot entry:
m-Aequivalent0..819100 in 100km:
0 km
SIE: thermal load:
10200 km
Additional coding:
Speed source:
via CAN
Coolant temperature source:
via CAN
Locking bit:
locked
Tank characteristic curve:
1
Number of fuel level sensors:
1
Units adjusted:
Temperature:
Ā°C
Distance:
Kilometers
Speed:
Kilometers per hour
Pressure:
Bar
Volume:
Liter
Time:
24h
Date:
dd_mm_yy
Consumption:
Liters per 100 km
SIA: maximum value of distance to service:
15000 km
SIA: maximum value of time to service:
372 d
Indicator light for start-stop operation:
active
Automatic door locking:
Yes
Pause recommendation:
Yes
Emergency telepone numer:
Status:
not active
Preselection:
000000000000
Telephoe numer:
Volume to be replenished:
Yes
Light warning buzzer, condition:
Driver door:
Open
Cylinder shut-off:
No
No
No
No
No
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
Bootloader:
1000
Application:
1000
Data record:
1000
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
00
Subassembly and series number:
ECUSupplierNumber:
3126
Year:
22
Month:
4
Day:
27
VD1-048
Day of manufacture:
20.05.12
7394
3126
Manufacturer's test stand number:
ECUProductionTestSystemNumber:
7394
VWSupplierNumber:
VD1
BAP
Primary version number:
1
Secondary version number:
4
Revision number:
1
OSEK - operating system
3
14
Revision number:
0
High Speed - Network management
1
12
Revision number:
1
6R0920870B
SoftwareVersion:
0605
Date of manufacture:
Year:
12
Month:
5
Day:
20
Serial number:
00000000000000
WVWZZZ6**"****113
6R0920870B
System description:
KOMBI
Device number:
100894
Importer number:
771
Dealership number:
29952
Year:
22
Month:
4
Day:
19
A04716
HardwareVersion:
H04
Device number:
60933
Importer number:
3
Dealership number:
12289
J285
0030
0006
0006
0000
0000
0000
0000
0000
0000
0000
Programmability:
programmable
Program present
Data consistency:
valid EEPROM data
no error
Parameterizability:
Parameterizable
Mileage: 190000 km
Backup
Control unit: 19 Gateway
System description: GW-K-CAN TP20
Software number: 6N0909901
Backup name: Gateway
Long coding:
002200
Mileage: 190000 km
Backup
Control unit: 25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03709
Backup name: Immobilizer
Long coding:
000000
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
Correct result
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
Correct result
Year:
0
Month:
0
Day:
0
Device number:
0
Importer number:
0
Dealership number:
0
Programming status:
Correct result
Year:
0
Month:
0
Day:
0
VD1-048
Day of manufacture:
20.05.12
7394
3126
BAP
1
4
Revision number:
1
3
14
Revision number:
0
1
12
Revision number:
1
5K0953234
SoftwareVersion:
0605
Serial number:
WVWZZZ*R******113
5K0953234
System description:
IMMO
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
0
Day:
0
A03709
HardwareVersion:
H04
2D2D2D2D2D2D2D2D
Device number:
0
Importer number:
0
Dealership number:
0
J334
0030
0006
0006
0000
0000
0000
0000
0000
0000
0000
Programmability:
programmable
Program present
Mileage: 190000 km
Backup
Control unit: 44 Steering Assistance
System description: LenkhilfeTRW V277
Software number: 6R0423156B
Backup name: Steering Assistance
Coding:
11220
Mileage: 190000 km
Backup
Control unit: 56 Radio
System description: Radio RCD510
Software number: 3C8035195
Software version: 0171
Hardware number: 3C8035195
Hardware version: 040
Serial number: VWZ1Z3K6347325
Backup name: Radio
Long coding:
0500040002
Adaptations:
Channel 002: 0
Channel 003: 60
Channel 005: 0
Channel 010: 0
Channel 011: 1
Channel 012: 1
Channel 013: 883
Channel 014: 540
Channel 016: 30
Channel 017: 0
Channel 018: 0
Channel 019: 0
Channel 022: 0
Channel 046: 0
Channel 050: 0
Mileage: 190000 km
Backup
Control unit: 77 Tlephne
System description: TELEFON
Software number: 7P6035730J
Software version: 3200
Hardware number: 7P6035730J
Hardware version: H15
Serial number: 00007663087507
ODX name: EV_UHVNA
ODX version: 002720
Backup name: Teephne
Long coding:
0201000000010110
Adaptations:
Analysis 1:
Access authorization required, perform Login
Number 2 for Info call:
C46771665500
Number 2 for roadside assistance:
C46771665500
Number 1 for Info call:
020665500F
Number 1 for roadside assistance:
020665500F
Bluetooth acknowledgement signal:
On
CDMA Detection:
CDMA Detection:
Not activated
Developer mode:
Developer mode:
Not activated
Masking of Languages:
Mask Byte 0/Bit0 Language - German:
valid
Mask Byte 0/Bit1 Language - English:
valid
Mask Byte 0/Bit2 Language - French:
valid
Mask Byte 0/Bit3 Language - Italian:
valid
Mask Byte 0/Bit4 Language - Spanish:
valid
Mask Byte 0/Bit5 Language - Portuguese:
valid
Mask Byte 0/Bit6 Language - Czech:
valid
Mask Byte 0/Bit7 Language - Russian:
valid
Mask Byte 1/Bit0 Language - US-English:
valid
Mask Byte 1/Bit1 Language - French-Canadian:
Invalid
Mask Byte 1/Bit2 Language - US-Spanish:
Invalid
Mask Byte 1/Bit3 Language - Dutch:
valid
Mask Byte 1/Bit4 Language - Swedish:
valid
Mask Byte 1/Bit5 Language - Polish:
valid
Mask Byte 1/Bit6 Language - Norwegian :
valid
Mask Byte 1/Bit7 Language - Turkish :
valid
Name of universal cell phne package (UHV):
VW PHNE�����������������������
Base volume of telephne:
Telepone basic volume output:
+ 00dB
Base volume of speech output:
+0.0dB
Micropone sensitivity:
Microphne sensitivity:
+ 00dB
Setting Bluetooth PIN:
0000
User profiles:
User profiles:
not erased
Delay of audio output:
0.0 s
Reference channel delay:
0 ms
Media playback volume:
+00dB
Emergency telephoe nuber:
Emergency telepone nuber:
000000000000000000
No
No
No
No
Bootloader counter:
0
UHVNAR Application Counter:
0
Bootloader counter:
0
0
1
1
Bootloader Lock Value:
65535
UHVNAR Application Lock Value:
65535
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
1
Day:
1
programming state:
Correct result
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
0
Day:
0
programming state:
Correct result
Year:
22
Month:
4
Day:
29
SJA-001
Day of manufacture:
17.07.12
0001
0174
1
Decoration variant:
B
001
001
BAP
Major Version:
1
Minor Version:
4
Revision:
1
UDS - protocol
Major Version:
1
Minor Version:
2
Revision:
20
Diagnostics - Event - Handler
Major Version:
1
Minor Version:
2
Revision:
5
CAN - driver
Major Version:
4
Minor Version:
2
Revision:
3
VW - TP2.0
Major Version:
1
Minor Version:
2
Revision:
14
ISO15765-2
Major Version:
1
Minor Version:
2
Revision:
21
Major Version:
2
Minor Version:
2
Revision:
0
OSEK - Network management
Major Version:
3
Minor Version:
7
Revision:
3
OSEK - Communication
Major Version:
2
Minor Version:
2
Revision:
0
Version number:
01
7P6035730J
SoftwareVersion:
3200
Serial number:
00007663087507
7P6035730J
System description:
TELEFON
Workshop code for connected tester:
Device number:
60933
Importer number:
3
Posted: Sun May 01, 2022 7:14 am
by Toymachine1
The problem in the below topic seems to be same as mine. There was not solution found for operating the menu with stalks though.
viewtopic.php?t=69586
I think we need to look at solution from how the integration between MFSW and stalks with the car differ. Could different stalks make a difference? I understood that some stalks have issues if a MFSW has been installed.
Posted: Sun May 01, 2022 8:39 am
by iichel
I think the solution is clear, install MFSW.
Posted: Mon May 02, 2022 8:35 pm
by Toymachine1
Yep I think I'll be doing that, but now need to have a small break from bigger retrofit stuff
Meanwhile I was thinking that I would try to code off instrument cluster in the GW module temporarily, to see if I could then pair my phone since MFD+ would be offline. Could this cause some issues with something? To pair the phone I would not even need to start the car, just have ignition on.
Also before ordering the wheel, I am thinking that I would try to flash my clusters SW from 0605 to 0607. (Any idea where to find change logs for SW versions?). Also need to find someone to do this job. I think this good step even if I would be to retrofit MFSW.
Then about MFSW, I kinda like the basic 6C MFSW (6C0419091E). I believe it should be fairly simple to retrofit. Now that I have the MFD stalk, do I need to run the two additional cables still as stated in the retrofit guide that can be found in these forums?
Thanks again.
Posted: Tue May 03, 2022 7:20 am
by iichel
I think it's easier to remove the 77 telephone from gateway, but I doubt it will solve your problem.
Posted: Fri May 06, 2022 10:03 pm
by Toymachine1
Most likely going for older Passat MFSW (3C8.959.538.F).
Those seem to be rather cheap with airbag and looming included, and also good enough looking for me. Ordered all the other stuff for completing the retrofit already, but need to wait until Monday to get confirmation if I can get the MFSW I have my eyes on now.
My plan of keeping break from working with the car has not been successful.
While I wait for the new wheel I just keep the Bluetooth module completely deattached from the car so I can operate other MFD menu's.
Super interested in getting GRA_high activated. I have same ECU as MaDwArLoCk. Wonder if someone can share the information required to enable it on the SIMOS10.2? Could it also require EEPROM changes in the instrument cluster? On the adaptation channels I get message that it is not available.
Referring to this
https://www.drive2.ru/l/520403252546633883/
Posted: Fri May 06, 2022 10:15 pm
by iichel
It's just an adjustment in the ECU flash file.
Posted: Fri May 06, 2022 10:20 pm
by Toymachine1
So much stuff to read in the internet
found this
viewtopic.php?t=73189&start=30
I am a starter with all this so plenty of stuff to learn. Instructions there are clear, but is help still available for adjusting the ECU file?
what about that HW and software?
Thanks.
Posted: Fri May 06, 2022 10:34 pm
by iichel
My knowledge about this is only hypothetical. You need to read the full flash from your ECU (with a suitable tool) and know what to adjust. And then re-flash the adjusted flash file.
Reading a flash is something a tuner can do. Adjusting the flash file is not something I can directly recommend someone for.
Posted: Sat May 07, 2022 10:19 pm
by Toymachine1
Hmm after some studying I am not sure if the PQ46 steering wheel will work on PQ25 (easily). PQ46 seems to have control unit for MFSW somewhere else than inside the steering wheel, where it's located for example in Polo 6R GTI.
At first I thought that the buttons have some controller integrated to them, as airbag loom connects to the left side button directly, and not to a separate controller. Will read more tomorrow, but if someone has insights regarding this, then all the help would be much appreciated.
Update: indeed after 2009 the Passat MFSW button controller is located in steering wheel control unit, which is a separate box under the steering column. Wheels before 2009 have this module inside the steering wheel. So it remains still undecided which wheel I will get. Trying to get this together with a lower budget since I just want the functions to work.
Posted: Sun May 08, 2022 7:55 am
by iichel
the 3C8 MFSW will work just fine on your Polo 6R. just remove or disconnect the MFA stalk buttons.
