I now think this issue is not because of the ABS sensor or its ring . Its something else which is causing the issue intermittently .
Issue Background
Please help me with your inputs to resolve the issueThere is no ABS light when I am starting the car.Whenever the car has ran for nearly 5-10 kms the ABS light automatically pops up.If I stop the car and remove the key fob and restart the car the ABS light doesn't comes up anymore.But again after running few kms the ABS light comes up.
I had a leaking rear left wheel cylinder and all the brake fluid had drained through it . I had replaced the rear left wheel cylinder and filled the brake fluid and bleeded the rear left wheel .I think after this the intermittent ABS issue is coming for this rear left wheel.
I am not sure if this is causing the issue as I always thought ABS error is related only with the ABS sensor and the corresponding ABS ring.
VCDS Scan Results
Sunday,17,April,2022,18:36:26:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWB10602AT000319 License Plate:
Mileage: 78220km-48603mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 09 15 17 19 25 44
VIN: WVWB10602AT000319 Mileage: 74360km-46205miles
Address 01: Engine (CJL) Labels: None
Part No SW: 03E 906 023 P HW: 03E 906 023 P
Component: SIMOS91 1.2l 4V 5811
Revision: --H05--- Serial number: 00000000000000
Coding: 0000031
Shop #: WSC 01234 785 00200
VCID: 2C57B2B28C0B312494-515A
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ABS82.clb
Part No SW: 6RF 907 379 HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0002
Revision: --------
Coding: 500200C1006D00B20A2800E300DA00004000
Shop #: WSC 02069 000 00000
VCID: 11290346CC697CCC87-8044
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 77
Reset counter: 10
Mileage: 77073 km
Time Indication: 0
Date: 2016.09.07
Time: 10:07:42
Hex Value: 0x0000
Hex Value: 0x8000
Hex Value: 0x12C1
Hex Value: 0x08B1
Hex Value: 0x17FF
Hex Value: 0x157F
Hex Value: 0x7C15
Hex Value: 0x1515
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 52
Reset counter: 47
Mileage: 77073 km
Time Indication: 0
Date: 2016.09.07
Time: 10:08:57
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3001
Hex Value: 0x088B
Hex Value: 0x03FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Part No SW: 6RU 937 086 HW: 6RU 937 086
Component: BCM25 IM M+4 H46 0207
Revision: BY046001 Serial number: 0118 289090026
Coding: 32B02BBF08A30C00003004003C2B04900040410F60040000200000000000
Shop #: WSC 124697 483 00190
VCID: 1E33687A09B7D3B40A-804A
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3411
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3411
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3411
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3411
Coding: 020000
1 Fault Found:
01758 - Bulbs for Brake Lamps
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 254
Reset counter: 50
Mileage: 77064 km
Time Indication: 0
Date: 2016.09.07
Time: 09:47:27
Part No SW: 6R0 959 655 E HW: 6R0 959 655 E
Component: VW10Airbag600 H09 0018
Revision: -------- Serial number: 003DY000EBLA
Coding: 003030
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4487FA12CF9BD9647C-8010
Part No SW: 6RF 920 860 HW: 6RF 920 860
Component: KOMBI X05 0006
Coding: 540800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
VCID: 071D2D1EBE2D327C59-8052
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 0207
Coding: 002340
VCID: 70EF66C2A3A315C4E8-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO X05 0006
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03003
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 01234
VCID: 2E53B8BAED174334BA-807A
End-------------------------(Elapsed Time: 02:01)--------------------------
