This is a stunning VW Polo 6C Blue GT 5-door leatherette, alcantara and cloth full airbag front and rear seat set with matching door cards from a low mileage car. As you can see it is stunning condition and has been full valeted. There is no wear, no holes and no damage. You will not find another in this condition! The front seats have side airbags, seats drawers under the seats, adjustable & removeable headrests and the rear seats also have adjustable & removeable headrests.
These will also fit a VW Polo 6R and are the same as the Polo 6R Blue GT, apart from the front seats have drawers under and the door cards have matt chrome trim strips at the top of the light grey leatherette panels. -£549. I'n in north-east Kent, UK. Please pm me if interested.
Polo 6C Blue GT 5-Door leatherette and alcantara seat & door card set
- Drives: 2013 Polo Blue GT
- unnamed-73.jpg (2.41 MiB) Viewed 4111 times
- unnamed-74.jpg (2.71 MiB) Viewed 4111 times
- unnamed-66.jpg (1.48 MiB) Viewed 4111 times
- unnamed-70.jpg (2.57 MiB) Viewed 4111 times
- unnamed-69.jpg (2.12 MiB) Viewed 4111 times
- unnamed-68.jpg (2.56 MiB) Viewed 4111 times
- unnamed-65.jpg (2.51 MiB) Viewed 4111 times
- unnamed-71.jpg (1.68 MiB) Viewed 4111 times
- unnamed-67.jpg (1.73 MiB) Viewed 4111 times
Re: Polo 6C Blue GT 5-Door leatherette and alcantara seat & door card set
Bear in mind that the 6C interiors will not be plug and play. The airbag system on the 6C and 6R is from a different generation. The only way a 6C to 6R retrofit (and vice versa) is affected is by the newer type of passenger detection mat. For everything to function well, the appropriate part should be installed. The 6R part number is 6R0963553A or ...C.
- 2022-02-07 09.34.28.jpg (1.59 MiB) Viewed 4083 times
- 2022-02-07 09.34.23.jpg (1.59 MiB) Viewed 4083 times
Thanks! I actually have one of those if anyone needs it to fit to a 6R.iichel wrote: ↑Thu Jun 23, 2022 8:32 am Bear in mind that the 6C interiors will not be plug and play. The airbag system on the 6C and 6R is from a different generation. The only way a 6C to 6R retrofit (and vice versa) is affected is by the newer type of passenger detection mat. For everything to function well, the appropriate part should be installed. The 6R part number is 6R0963553A or ...C.
Perfect. I just wanted to save you from the trouble if someone were to mistakenly and unknowingly put it in a 6R
Is that just for the passenger air bag to work when a passenger is in the car? If so, I guess if I'm fitting non VW seats and it won't be possible to get the airbags working in the non VW seats (due to a different resistance), then there's no point in fitting it?
