Auto light loom
- Drives: Transporter
Auto light loom
Hi guys
I’ve been surfing the net for some time now and struggling to locate a auto light loom.
I found a few old threads but can’t find the how to or any info where I can buy one.
Used or new either or.
Thanks in advance
Thanks in advance
Re: Auto light loom
Does you car meet the requirements? BCM max 088/089/090 and rain and light sensor
Re: Auto light loom
I’m sure it’s bcm max. I’ve retrofitted dimming mirror and rain sensor went to fit auto lights and noticed that my light switch is the big plug
Re: Auto light loom
It depends on the answer on my earlier questions
Re: Auto light loom
I’m currently away and won’t be back until next week to check, but I’m almost certain it’s the top BCM
Failing that if it isn’t.. I can get a BCM that would allow me to have these options correct?
Re: Auto light loom
Yes you can retrofit all you want... BCM, autolight, bixenon, but it all depends on how much work it is and how capable and comfortable you are with making wirings and/or installing wirings and performing coding.
Re: Auto light loom
Fairly comfortable with it, are you able to help? Or make the auto light loom and I can make the rest?
Re: Auto light loom
I can make an auto loom if you have the BCM max. Or if you're handy with wirings yourself, you could make it yourself. If you do not have the BCM max, you need to make a complete BCM max conversion. That is not a one size fits all solution.
The bixenon conversion itself is a matter of coding and adding one or two wires per headlight and a different plug. If you have the BCM max. And the auto levelling headlight system if you like/need.
Re: Auto light loom
Could you drop me a PM please ? It won’t allow me to message you direct I think due to being new?
Re: Auto light loom
Why a PM? This is fine, right?
Re: Auto light loom
That’s fine,
I’ll find out what bcm I have
It’s for a transporter T5.1 but I’ve noticed they share a lot of electrics with polos and ready various posts it’s pretty much the same todo to a polo then a transporter.
The part number on the bcm is as follows: 7H0937087P
It’s the high line model
Re: Auto light loom
In that case you will need to upgrade your BCM to 089/090 and do all adaptations to your electrical installation. There are some topics on the BCM max retrofit here. There you will find a lot of information on this subject.
