Hey guys
I'm wondering if anyone knows the dimensions (width / length) of a polos boot with the rear seats forward.
Or basically the length of the longest and fattest thing i can fit in there with seats down
I'm away atm so cant measure for a few weeks or 2 need to know asap and couldnt seem to find online
2013 Polo S - Boot space
Re: 2013 Polo S - Boot space
I find many information sources don’t give the actual luggage space dimensions - just the cubic capacity in litres. However, I stumbled upon the RIDC (Research Institute for Disabled Consumers) website which does give dimensions, so prospective owners can check if their mobility equipment will fit in the car.
The pdf document at the link below gives the measurements for a 2016 Polo Bluemotion. That car shares the same body shell as a 2013 Polo S so the boot dimensions should be the same. Hopefully it gives you the information you need;
https://www.ridc.org.uk/print/pdf/node/3904
