UK-POLOS.NET - THE VW Polo Forum • Beware: The soft limiter bypass videos…
Posted: Tue Oct 04, 2022 6:30 pm
by ad_182_uk
Came across this which appears to show someone showing how to ‘bypass’ the soft limiter on the DSG.
From what people say the limiter is there to protect the gearbox when in park / neutral, although if it’s that dangerous why can you rev it at all…
Anyway - video in question here, seems innocuous but those claiming to have mechanical experience suggest it’s not good.
Im guessing as one off whoever it is in the video may get away with it, although after asking it appears they have blocked my comments on youtube or removed the vid so take from that what you will.
https://youtube.com/shorts/FWFLTppcZyM?feature=share
Re: Beware: The soft limiter bypass videos…
Posted: Tue Oct 04, 2022 7:17 pm
by lancslad1985
The video has been set to private, as I can’t see it either and I haven’t commented.
Posted: Tue Oct 04, 2022 7:33 pm
by OomStu_ZA
Interesting, I was able to see it a while back and confirm it is now blocked. Basically, the chap said to put the gear lever between Park and Reverse. This would remove the gear indicator from the digital display and then reved it to 7000 RPM. Quite a silly idea if you ask me.
Posted: Tue Oct 04, 2022 7:59 pm
by ad_182_uk
Yes that is pretty much what he did. Handbrake on and foot on both brake pedal and accelerator.
Hopefully he did it once and got away with it. I have no idea how many times / how long you would have to do this to cause damage. Not about to test it out though! :lol:
Posted: Tue Oct 04, 2022 9:19 pm
by SRGTD
OomStu_ZA wrote: Tue Oct 04, 2022 7:33 pm Interesting, I was able to see it a while back and confirm it is now blocked. Basically, the chap said to put the gear lever between Park and Reverse. This would remove the gear indicator from the digital display and then reved it to 7000 RPM. Quite a silly idea if you ask me.
Agree; a silly idea.
I’ve not even used launch control in my car in just over two years of ownership so I’m hardly likely to want to bypass the soft limiter.
Posted: Wed Oct 05, 2022 6:30 am
by lancslad1985
Maybe I’m just getting old but my main thought on this was “why?”.
