Shock absorbers
littlepolo
Shock absorbers
Post by littlepolo »
Does anyone know what make of shock absorbers were originally fitted to the Polo (2002)?
4aceman
Drives: Polo 9n 1.4 auto BKY
Re: Shock absorbers
Post by 4aceman »
Usually OEM for german car manufacturers is Sachs.
Can’t go wrong with them. I’ve also had good luck with Bilstein B4s on other cars. They’re usually a bit firmer than stock though
4aceman
Re: Shock absorbers
Post by 4aceman »
littlepolo
Re: Shock absorbers
Thanks. I was just prepping in case the ones I removed (to fit new bump stops) were on the way out. I was relieved to find they are Sachs Gas shocks and excepting a bit more pitting on the nearside shock body still good for many more miles. Cleaned up, rust proofed and painted. Near side spring is losing its plastic coating and cross member/axle beam paint flaking. Will attend to them in the spring.
