Are these normal MAF readings?
Posted: Fri Nov 18, 2022 3:18 pm
by mirceaculita
I did a test where I read the values returned by the MAF sensor and these were the results.
3000RPM ~= 30g
4000RPM ~=40g
It seemed to peak at 80g when flat out in first. Rest of the time flat out it seemd to return 60-70g.
At idle it's around 6g to 7g.
I'm curious if these are normal readings for a 1.2TDI
Thanks!
Re: Are these normal MAF readings?
Posted: Fri Nov 18, 2022 3:47 pm
by iichel
yes, about 1 gram per 100 rpm sounds about right, 2-3mg air per stroke is ok
