No spark
Mikeb-25
Drives: Polo
No spark
Post by Mikeb-25 »
Hi. I'm new so please be patient 😆
I have a polo 1.2 2006 3 cylinder, engine code BME.
I've changed my timing chain, spark plugs was removed and battery disconnected. all timing marks pins and locks was used and rotation of the engine was done and timing pins and locks was put back and locked in place easily.
No the engine turns over but I have no spark on any of the 3 cylinders.
I've tried all the fuses and none are blown,
I've put new spark plug in but still no spark. Plugs come out smelling of fuel. Ive even tried the Connecting the battery terminals together for 1hr to drai. The power from the ecu to see if that resets any issue but no joy. Connected to the snap on and brings no codes up.
Any help would be helpful
Thanks in advance
Mike
Brian422
Drives: 2013 Polo 1.2 Match Edition
Re: No spark
Post by Brian422 »
Was the engine running before you changed the timing Chain?
