Rattling Vibration Noise
Posted: Sat Dec 10, 2022 9:45 am
by Casbantam
Hello all,
Can anyone help? I have a 1.2 Polo TSI 2016 43k.
A few weeks ago I started to get a bit of an annoying rattling noise when driving slow. It sounds like plastic rattling coming from under the bonnet somewhere. Like something has worked loose? I started with just a single rattle on startup and then rattling a little as I was driving slowly in 1st gear.
It seems to have got worse since then as it seems more noticeable now more of the time. I was on the motorway yesterday and it did feel like I could feel a bit of vibration in the steering wheel and floor??
It drives fine and has just last month been serviced and passed Mot. Cam belt was changed 12 months ago.
I have hit a couple of Bad potholes recently so wonder if this could be linked?
Any help appreciated thanks.
Re: Rattling Vibration Noise
Posted: Tue Dec 13, 2022 3:05 pm
by 2fast4ya
Could be a thrown wheel weight , or possible alloy damage , these will cause vibration on the steering & also make bits in the dash rattle a little , but could be damaged bushes , link rods, etc , check around all them to rule them out , check for damaged tyres , sometimes hitting potholes can cause bulges & splits on the innerside of tyres n makes vibration .& apart from that check for loose bits under the scuttle panel area ,
Posted: Tue Dec 13, 2022 9:21 pm
by Casbantam
Cheers 2fast4ya.
I had 2 new rear tyres fitted last week so will start there I think. Maybe not balanced properly?
It's like a weird noise / vibration not easily noticeable but I can tell that it's there. I can feel the slight vibration through the floor and a little through the pedals and steering wheel.
Posted: Tue Dec 13, 2022 11:59 pm
by 2fast4ya
Could be that mate?
i hate the balancing weights lol i had new tyres fitted not so long ago & the wheels balanced aswel but they dont stick well or the machanics dont press them on hard enough , i heard a couple of mine come off & flung around wheels never to be seen again .
Posted: Wed Dec 14, 2022 8:32 pm
by Casbantam
Hoping so.
Booked in tomorrow morning so hopefully will sort it out
Posted: Thu Dec 15, 2022 9:45 pm
by spartacus68
Worth having a look at the ARB links.
Posted: Fri Dec 16, 2022 12:07 pm
by Brian422
Did this rattle occur immediately after service?
This may sound weird but some time ago, after removing and replacing Air Filter box, I had an annoying plastic rattling noise.
Quickly found lug on Air Filter box rear had not correctly located in rubber grommet.
Posted: Fri Dec 16, 2022 9:21 pm
by Casbantam
Just randomly started.
Fortunately I found an earlier post from Bepis who suggested loose caps on top of the shock absorbers. Worked a treat and rattle solved.
Posted: Sat Dec 17, 2022 12:38 pm
by Brian422
Happy to hear rattle resolved and one to look out for.
