Hi All, I have the following problem on Polo 9N, 2005.
None of the interior lights are working (just bought the car, so don't know the history). Fuse 10A (no 28) is OK, replaced anyway. Checked with voltmeter and 12Vdc are coming to the fuse contacts.
Then, I removed forward main interior lamp. It has 3-core supply cable, when I try to measure the voltage between the cores of this cable I get something like 6V, 5V and 2V.
Any suggestions where to dig for solution?
Thanks!
9N interior light issue
- Drives: 9N
- Maarten
- Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: 9N interior light issue
Does the door open light on your cluster light up when your door is open?
