Hi iichel, dhaswirken
I own a polo sedan 1.6 tdi 77kw manual transmission and it has ran around 207000 kms and am very interested to swap from manual to dsg. With all the references had on this forum we have started the swap process and got the hardware changes done. Following is the stock VCDS log of the car
Monday,08,January,2024,13:03:35:39744
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWL12600DT028477 License Plate: 1777
Mileage: 206510km-128319mi Repair Order:
Chassis Type: 60 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: WVWL12600DT028477 Mileage: 206510km-128319miles
Address 01: Engine (J623-CLNA) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9811
Revision: --H33--- Serial number:
Coding: 00110016030500080000
Shop #: WSC 99999 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023NT 003010
ROD: EV_ECM16TDI02103L906023MJ.rod
VCID: 05064A5684BA6669DA-8050
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6RF 907 379 A HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 500200C1006F00BA0A2900E900D800000000
Shop #: WSC 02069 000 00000
VCID: 52ACA10A097401D10F-8006
Part No SW: 6R0 907 044 J HW: 6R0 907 044 J
Component: Climatronic H11 0610
Revision: V0000000
VCID: 3A7CE9AAB5C4D991E7-806E
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
000 - -
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 24
Mileage: 199906 km
Time Indication: 0
Date: 2018.01.15
Time: 22:22:25
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 D HW: 6RU 937 086
Component: BCM25 IM M+4 H47 0254
Revision: BY047001 Serial number: 0384 290123940
Coding: 3A904ABF08A10000003800002C2B84910000410F60040000200000000000
VCID: 62CC71CA7DD4F1519F-8036
Subsystem 1 - Part No SW: 6R0 959 802 D HW: 6R0 959 802 D Labels: 6R0-959-802.CLB
Component: ------------- 002 3424
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 F HW: 6R0 959 801 F Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0233248
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Component: J388__TSG_HL 002 3424
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Component: J389__TSG_HR 002 3424
Coding: 020000
1 Fault Found:
03591 - Control Circuit for Horn
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 62
Mileage: 206034 km
Time Indication: 0
Date: 2018.05.20
Time: 19:54:09
Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361224301444
Coding: 108002
Shop #: WSC 00793 648 00255
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E74E5BAA1ECF5B1DB-806A
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00DVLRE
Coding: 003036
Shop #: WSC 01383 785 00200
VCID: 499E8666E82242097E-801C
Part No SW: 6JA 920 840 E HW: 6JA 920 840 E
Component: KOMBI H01 0711
Coding: 140800
Shop #: WSC 73430 031 00161
VCID: 3D76E2B6ACEAEEA9C2-8068
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 184841 km
Date: 2022.12.02
Time: 23:40:24
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H47 0254
Revision: BY047001
Coding: 002300
VCID: 70E80B82A33853C119-8024
Component: IMMO H01 0711
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 J HW: 6RF 909 144 J
Component: EPS_ECU H28 0401
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK_SK26.rod
VCID: 53A2A40E3A6E08D904-8006
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:46)--------------------------
Installed esp module, dsg gearbox and following are the post swap VCDS log
Monday,05,February,2024,21:31:20:61752
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
Mileage: 207210km-128754mi Repair Order:
Chassis Type: 60-VW25 (XXX)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWL12600DT028477 Mileage: 207210km-128754miles
02-Auto Trans -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 KE HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9978
Coding: 00000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM16TDI02103L906023KE 003009
ROD: GV_ECM16TDI021VW32X.rod
VCID: 73B3DDE5CB3A3B137E0-8026
10 Faults Found:
7295 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [165] - Signal too High
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2024.02.05
Time: 00:01:16
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 33 C
Intake air temperature: -40 C
Ambient air pressure: 980 mbar
Voltage terminal 30: 11.972 V
Engine RPM: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Charge air pressure: specified value-MAP_SP_MMV: 200.00 hPa
Charge air pressure: actual value-MAP_MMV: 200.00 hPa
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 81.445 %
7308 - Intake Air Temp. Sensor (G42)
P0113 00 [037] - Signal too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2024.02.05
Time: 00:01:16
Voltage terminal 30: 12.085 V
Engine RPM: 0 /min
Outside temperature-Ambient temperature: 9.00 C
Battery voltage: 12.1 V
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0 /min
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
9857 - Engine Control Module Incorrectly Coded
P1612 00 [165] - -
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 0.000 V
Coding in the engine control module-FRF_VARCOD: 1
Number of resets of main unit-CTR_RST_MC: 0
Control Module temperature-TECU: 23 C
14355 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [165] - Malfunction
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
14356 - Exhaust Gas Temperature Sensor 4 Bank 1
P246E 00 [165] - Electrical Malfunction
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
7345 - Diesel Particle Filter; Differential Pressure Sensor
P2455 00 [165] - Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2024.02.05
Time: 00:01:16
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 9.10 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 9.10 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 65535 km
Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 0.0000 s
Particle filter: difference pressure-DIP_PF: 1092.44 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 15
Sensor for temp after charge air cooler: raw value-TBA_MES: -40 C
9867 - Coolant Pump 2
P261A 00 [037] - Open circuit
Fault Priority: 2
Fault Frequency: 1
Mileage: 207211 km
Date: 2024.02.05
Time: 00:01:40
Coolant temperature at radiator outlet: actual value-TCO_2: 8 C
10453 - Output for Starter Relay
P0615 00 [037] - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0 /min
Starter activation: status-FRF_ST_RL: 1
Sensor for engine block temperature: raw value-Coolant temperature: 32 C
10938 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 00 [165] - Signal too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 0 km
Date: 2024.02.05
Time: 00:01:16
Readiness: 0 0 0 0 1
Part No SW: 0AM 300 041 B HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2606
Revision: 00005009 Serial number: CU502106055080
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 2809FA894EFC08CB1B2-807C
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Fault Priority: 0
Fault Frequency: 9
Reset counter: 10
Mileage: 207211 km
Time Indication: 0
Date: 2018.06.28
Time: 00:06:43
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 000000000000000000000000000000000000
Shop #: WSC 01234 785 00200
VCID: 0B43A505B3CA43D3160-805E
5 Faults Found:
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[IISOEMCalibrationError]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Date: 2024.02.05
Time: 00:03:39
0887 - Control Module
C104A F0 [137] - Incorrect VIN
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Date: 2024.02.05
Time: 00:03:39
0883 - Control module not coded
U1013 00 [137] - -
[VehicleConfigUncoded]
Fault Priority: 2
Fault Frequency: 3
Reset counter: 32
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
0354 - Front Left Wheel Speed Sensor
C101A 01 [137] - Electrical Failure
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Date: 2024.02.05
Time: 00:55:21
0392 - Front Left Wheel Speed Sensor
C101A 01 [129] - Electrical Failure
Serial number: 30071613471336
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FCD1F078667B01E-802A
Address 08: Auto HVAC
Cannot be reached
Part No SW: 6RU 937 087 P HW: 6RU 937 087
Component: BCM IM H+4 H41 0444
Revision: BZ041001 Serial number: 8700 281160109
Coding: 3A904BFF08A10000013800006E0B06900080600F608E0100220000000A00
Shop #: WSC 124697 483 00190
VCID: 6FBBD195A7921FF39A8-803A
Subsystem 1 - Part No SW: 6R0 959 811 E HW: 6R0 959 811 E
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 812 E HW: 6R0 959 812 E
Coding: 020000
5 Faults Found:
03429 - Activation of Right Adaptive Light
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Time Indication: 0
Date: 2018.06.28
Time: 00:06:44
01179 - Incorrect Key Programming
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Time Indication: 0
Date: 2018.06.28
Time: 00:52:05
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Time Indication: 0
Date: 2018.06.28
Time: 00:06:48
01331 - Door Control Module; Driver Side (J386)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Time Indication: 0
Date: 2018.06.28
Time: 00:06:48
01520 - Rain and Light Recognition Sensor (G397)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 207211 km
Time Indication: 0
Date: 2018.06.28
Time: 00:06:48
Coding: 003036
VCID: 49CF5F0DF93611C3E4C-801C
2 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 207211 km
Date: 2024.02.05
Time: 00:06:47
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 207211 km
Date: 2024.02.05
Time: 00:06:47
Coding: 140800
VCID: 3D273BDDBDFEBD63584-8068
8 Faults Found:
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
9453330 - Outside temperature sensor
B103F 1B [008] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
[Steuerger t defekt (SiWaLa)]
Fault Priority: 2
Fault Frequency: 1
Mileage: 184841 km
Date: 2022.12.13
Time: 23:40:24
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger t f r Getriebe: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger t f r Bremse: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger t f r BCM / Bordnetz / el. ZE: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger t f r Airbag: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger t f r Lenkhilfe: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H41 0444
Revision: BZ041001
Coding: 002300
VCID: 196FCF4D0996A14394C-804C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Serial number:
VCID: 6A8DC0819CF0FADBCD6-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Coding: 0000
ROD: EV_SteerAssisUDSNSK.rod
VCID: 53F37D652B7A5B139E0-8006
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 01:10, VBatt start/end: 12.2V/12.2V)-----------
Need your help regarding engine coding and esp coding. Kindly do the needful. Also we dont have dpf installed on the vehicle. Let us know possible ways to disable dpf and start stop
Thanks in advance.
