Help needed for Cluster swap on a Polo 6C
POLOZ
Post by POLOZ »
So recently bought a JDM 6C polo and looks like somebody has slapped a MPH on a KMPH speedometer :(
Can I fit a second hand cluster?
Anybody in North West of England able to do it for me?
Re: Help needed for Cluster swap on a Polo 6C
You can probably fit a second hand cluster but it is not a plug and play swap. You will have to have it adapted by a professional.
giannis20vt
Post by giannis20vt »
I have done this swap.
Take a look at this link
https://www.uk-polos.net/viewtopic.php?t=69644&start=15
Of course you need a garage with online connection to apply the new (used Cluster) to the VW's servers and to remove the CP
POLOZ
Post by POLOZ »
giannis20vt wrote: Thu Feb 02, 2023 1:47 pm I have done this swap.
Well went to a guy who said he will fix the cluster and didn't even have the knowledge on how to fix it :|
Anyways am definitely going with a replacement cluster as nobody here has the knowledge on eeprom to change the scale from kmph to mph :roll:
will I need a odis? Or can it be done using autel?
also which cluster should i go with? 6C0920940G?
I think the only safe option is online odis.
POLOZ
Post by POLOZ »
iichel wrote: Sun Feb 05, 2023 7:46 am I think the only safe option is online odis.
Ok will try to find somebody local. Bought the new cluster :)
POLOZ
Post by POLOZ »
Well finally sorted out the cluster :) Ended up getting 6C0920940A and a very kind gentlemen came and sorted out the coding. Correct speed output is now shown :D
No errors or faults in VCDS
POLOZ
Post by POLOZ »
Now I have a spare Speedometer and would love to play with EEPROM
Can anybody tell me by looking at the pic below where the main eeprom chip is located?
There is a 16 pin chip on top right corner with code 25Q064A so I feel thats where the eeprom chip
I'm guessing top left with 8 pins.
POLOZ
Post by POLOZ »
iichel wrote: Wed Feb 15, 2023 8:12 am I'm guessing top left with 8 pins.
Top left microchip has the following number
A1040A
Does this sound right?
I'm expecting something like 24C... or 95C...
What about the other side of the board?
POLOZ
Post by POLOZ »
Nothing on the other side
There is a 16 pin microchip with label 25Q064A
Hm, perhaps it is in the MCU so no traditional chip
POLOZ
Post by POLOZ »
iichel wrote: Wed Feb 15, 2023 11:29 am Hm, perhaps it is in the MCU so no traditional chip
So which eeprom tool could I use?
I don't think it's possible to read it: https://mhhauto.com/Thread-Where-is-the ... K7-Cluster
