Condensation on inside of windscreen 2004 9N
Posted: Sun Feb 05, 2023 9:05 am
Trying to work out why my daughters windscreen keeps having condensation over night.
There are no cracks in the screen and the floor carpets are dry. The aircon recirculating light stopped working so I have replaced the vent motor although not sure its in the correct position as you can now put aircon on when the heater is on and it used to be just only if it was set to cold. Wondering if this is putting the vents in the wrong position and letting in cold air etc. Bastard job to do as when you remove the vent motor the vent flaps move and you have no idea of where they should be when putting the motor back.
Anyway, is there anything else I can check as it only stated doing it and it has not happened before in the last 5-6 years.
Any help or advice appreciated
Andrew
Andrew
