Throttle body cleaning? Suns out so starting to think about all the little jobs I'd like to do.
Cleaning the throttle body is on my list. Thing is, if I remove it will I need to re-adapt it? Or is the car smart enough sort itself out. Is there a trick/cheat to get the car to perform one?(CABG 1.2Tsi)
- Drives: 6R1-1.2 TSI (2011, CBZB, 77Kw, 35Kmiles)
- Maarten
- Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: Throttle body cleaning?
On my 9N3 I never did an alignment or adaptation after cleaning it.
I did not take off the part completely, just cleaned it with a rag.
Just clean it with contact off.
After a few km/miles it adaps itself if nessesary
I assume the 6R/6C will be that smart also
I think the 6C does this every time you start.
At least mine seems to go through a open/close cycle when turning the key before starting. Does weird throttle noises like it is moving it fully open to closed.
- Le_Combattant
6C does automatic adjustment each time engine stop.
But it's always better to perform an adaption true VCDS or OBDElven after cleaning
- mirceaculita
- Drives: 6R 1.2TDI 75hp
Same with the 6R. You can hear it
