UK-POLOS.NET - THE VW Polo Forum • Throttle body cleaning?
Posted: Mon Feb 06, 2023 12:21 pm
by wolfie
Throttle body cleaning? Suns out so starting to think about all the little jobs I'd like to do.
Cleaning the throttle body is on my list. Thing is, if I remove it will I need to re-adapt it? Or is the car smart enough sort itself out. Is there a trick/cheat to get the car to perform one?(CABG 1.2Tsi)
Re: Throttle body cleaning?
Posted: Mon Feb 06, 2023 12:59 pm
by Maarten
On my 9N3 I never did an alignment or adaptation after cleaning it.
I did not take off the part completely, just cleaned it with a rag.
Just clean it with contact off.
After a few km/miles it adaps itself if nessesary
I assume the 6R/6C will be that smart also :lol:
Posted: Mon Feb 06, 2023 6:42 pm
by 2226
I think the 6C does this every time you start.
At least mine seems to go through a open/close cycle when turning the key before starting. Does weird throttle noises like it is moving it fully open to closed.
Posted: Mon Feb 06, 2023 7:44 pm
by Le_Combattant
6C does automatic adjustment each time engine stop.
But it's always better to perform an adaption true VCDS or OBDElven after cleaning
Posted: Mon Feb 06, 2023 9:28 pm
by mirceaculita
Same with the 6R. You can hear it
