2007 Polo Dash display
Posted: Wed Feb 08, 2023 8:19 pm
Hi I have a 2007 Polo 9N3 1.4 Automatic. It is the version with the signle line red LCD dash displa to show which mode it's in is PRNDS or if I switch to the semi manual mode 654321
Recently I have noticed that at times the pixels onthe display can be intermittent. The display has not failed and many times it will display perfectly, but other times there will be gaps in the letters.
Has anyone else encountered this problem? is it a connection issue or does the LCD panel need replacing?
If the latter I wonder if anyone could advise if it is available and where from?
Unsure if related but occasionally in this car if the fuel tank is about half full, from time to time I'll hear the low fuel chime and the fuel guage will go to empty and then a few seconds later return to it's original position. I'm unesure if this is a tank sensor issue or a possible fault with the dash....
