EPC/Engine Light
EPC/Engine Light
Installed an apple carplay system https://www.ebay.co.uk/itm/37444969281 ... edia=COPY and also wired it into ignition fuse so it turns on and off. Everything was working fine but after 10 mins of driving EPC light came on, so I turned engine off and back on, EPC light stayed on and now the USB port in the unit doesn’t work. Decided to keep driving and then the engine light came on. Any help/advice? (Also have taken it out and put oem system in and still lights are on)
- Maarten
- Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: EPC/Engine Light
Did you check all the fuses?
Did you do an auto scan?
Adress 01 & Adress 09 most likely have some codes stored
