Will replacing the battery result in error codes?
Posted: Fri Apr 14, 2023 1:15 pm
by Luka
So I've got AW1 1.0 TSI 70kw/95h model. Car is now 5 years old. I've got a Topdon BT100 battery tester and I'm not able to test the state of the battery without removing the whole plus connection clamp/box since I can't see the battery specs to test it correctly. Will disconnecting the battery result in error codes from the car?
Re: Will replacing the battery result in error codes?
Posted: Fri Apr 14, 2023 1:38 pm
by iichel
Only some codes about the battery being disconnected. Nothing permanent, unless you keep it off for days at end.
Posted: Fri Apr 14, 2023 11:11 pm
by RUM4MO
Why not just assume that it is a 320A DIN and use that value when testing it?
Posted: Sun Apr 16, 2023 8:06 pm
by Luka
iichel wrote: Fri Apr 14, 2023 1:38 pm
Awesome, thank you!
RUM4MO wrote: Fri Apr 14, 2023 11:11 pm
Because the reading will be incorrect, I assume anyway.
Posted: Tue Apr 18, 2023 5:28 pm
by grazuncle2
you could get an OBD lead specifically made t keep the Memory alive/powered
you need a little 12v power supply for it.. I us my emergency jump starter for that.
Posted: Tue Apr 18, 2023 6:07 pm
by RUM4MO
Luka wrote: Sun Apr 16, 2023 8:06 pm
Awesome, thank you!
Surely all your battery analyser/tester will or can test for is the voltage across the terminals and the theoretical CCA DIN or EN, new batteries when charged and before being connected up into a car circuit will give a crazy high CCA reading, both my new batteries, AGMs tested as being at least 10% over the value printed on the battery.
Any time I've tested/checked car batteries, I've accepted the value being given while the battery is still connected to the car, charged up then left for 8 hours with the ignition etc off, so all controllers in their sleeping mode, ie minimum current draw.
Edit:- actually the 760A CCA (EN) still not used AGM Bosch, tested as 900A CCA (EN) when first bought and not fitted to a car, so the "out of circuit" test result should give you a falsely high value - or at least a value that does not reflect the useful life remaining in that used battery.
Posted: Tue Apr 18, 2023 6:13 pm
by RUM4MO
grazuncle2 wrote: Tue Apr 18, 2023 5:28 pm
I agree, so easy and obvious especially if you are the sort of person that spends money on a battery analyser - well I have what you suggested AND a CTEK battery analyser.
I've also got a CTEK 12V DC support/maintenance unit, but save that for other times.
