Page 1 of 2
Old VW antics
Posted: Tue May 30, 2023 9:05 am
by littlepolo
On a warm day (low 20s) where the Polo has been parked up during the day and I drive it after I turn on the sidelights. At the same time, the rear fog lamp warning light illuminates as does the lamp itself. After driving for say 10-15 mins, I try the sidelights again and this time the rear fog lamp does not illuminate.
I've had a similar issue in the winter time, especially when the it's foggy and the air is damp, e.g. during November. Any thoughts on the likely cause?
Re: Old VW antics
Posted: Tue May 30, 2023 9:13 am
by iichel
sounds like a short circuit somewhere, but you'd expect that to occur at colder and/or wet weather rather than hot-ish weather
Re: Old VW antics
Posted: Wed May 31, 2023 11:49 am
by littlepolo
It does exhibit odd behaviour during hot weather and cold weather. Reversal of the power windows left to right and up to down (everything backwards) durign wet winter weather is the most interesting!
Re: Old VW antics
Posted: Fri Jun 16, 2023 5:26 pm
by littlepolo
The latest oddity I've seen in hot weather is front n/s position lamp on with lights switched off and ignition off. When I went for a drive I put on the side lights and then the rear for came on again!
Re: Old VW antics
Posted: Mon Jun 26, 2023 9:20 am
by littlepolo
Update. When switching on side position lamps while engine is running/under way, the instrument cluster LEDs dim.
Re: Old VW antics - updates
Posted: Sat Jul 29, 2023 3:28 pm
by littlepolo
No 'whoosh' sound when opening the petrol filler cap.
No warning buzzer when sidelights left on (some of the time)
Re: Old VW antics
Posted: Sat Aug 12, 2023 10:50 am
by littlepolo
Gear position indicator LED segment not illuminating completely. I thought I had fixed this with the removal of the instrument panel and re-soldering of prime suspect joints.
Re: Old VW antics
Posted: Sat Aug 12, 2023 12:54 pm
by RUM4MO
littlepolo wrote: Mon Jun 26, 2023 9:20 am
Is this not intentional? For instance when you need headlights(side position lights on their own are not legal in UK if you are moving) on the ambient lighting level is lower and so if the instrument panel lights stayed at their daylight brightness, then they would be annoying and probably causing your eyes to "close down" a bit and that would reduce your vision of what is going on out with the car.
Posted: Sat Aug 12, 2023 12:56 pm
by RUM4MO
littlepolo wrote: Sat Jul 29, 2023 3:28 pm
I'm not convinced that I always notice a "whoosh" when removing the fuel cap to refuel, but I maybe just guessing that bit.
No warning buzzer when side lights are on and you open the driver's door points to a wiring failure or door lock function failure.
Re: Old VW antics
Posted: Sun Aug 13, 2023 3:32 pm
by littlepolo
RUM4MO wrote: Sat Aug 12, 2023 12:54 pm
That is a very good explanation!
Posted: Sun Aug 13, 2023 3:36 pm
by littlepolo
RUM4MO wrote: Sat Aug 12, 2023 12:56 pm
The thing is, there was a whoosh on occasion (not always) and now there is not.
Yes, potentially a wiring or door lock issue. In total with the strange things going on with the rest of the electrics (crossed electric window operation, fog lamps coming on with side position indicators, and tailgate not unlocking on central locking and intermittent rear wiper operation, etc.) makes me wonder.
Re: Old VW antics
Posted: Wed Oct 11, 2023 9:53 am
by littlepolo
Recent fuel consumption calculated at 45mpg (60/40 highway/urban). Knocking has not been such an issue this summer, possibly due to the milder temps.
Re: Old VW antics
Posted: Fri Nov 03, 2023 10:26 am
by littlepolo
I was surprised to record 47mpg 60/40 highway/local recently.
Re: Old VW antics
Posted: Mon Nov 20, 2023 4:28 pm
by littlepolo
Emissions results at recent MOT:
Fast idle
CO 0.00 % vol
HC 11 ppm
Lambda 1.001
Natural idle
CO 0.02 % vol
Re: Old VW antics
Posted: Mon Nov 20, 2023 4:29 pm
by littlepolo
the fuel filler flap has got a bit of spring in it (from somewhere) and now needs to be held in to be locked (on the key).
