Polo 6R Door Lock issue
Posted: Tue Jul 25, 2023 7:53 am
Hello everyone.
I have a problem with the left front lock on my Polo.
I start by saying that I bought 3 different ones and they give me the same defect...practically with the old original lock the car blocks regularly, while with the new one it doesn't want to block.
Here is a video to understand how it behaves.
https://drive.google.com/file/d/1NoyHhL ... sp=sharing
I also tried with VCDS and this is all the scan log:
In module 09, the error is:
Anyone know how to help me? Thanks in advance.
Tuesday,04,July,2023,15:15:44:00009
VCDS Version: 23.3.0.0 (x64)
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVWZZZ6RZBY129884 License Plate:
Mileage: 242010km-150378mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 61
VIN: WVWZZZ6RZBY129884 Mileage: 242010km-150378miles
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 B HW: 03P 906 021 B
Component: R3 1.2l TDI H04 9978
Revision: 12004001 Serial number: Dataset Number: 4F0909444AA D001 CVN: BD9C8E68
Coding: 00114014032400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TDI03103P906021B 001041
ROD: EV_ECM12TDI03103P906021B.rod
VCID: 275D4E9B5EED1DABA2-8072
VINID: 9E69EAAAA1A2A92A4108920810A2DBE8E9
1 Fault Found:
16261 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [216] - Implausible Signal
MIL ON - Intermittent - Confirmed - Not Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 241001 km
Date: 2023.06.18
Time: 18:33:07
Engine RPM: 957.75 /min
Normed load value: 99.2 %
Vehicle speed: 36 km/h
Coolant temperature: 79 Β°C
Intake air temperature: 33 Β°C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.812 V
Unlearning counter according OBD: 56
Accelerator pedal travel-Position: 69.4 %
Charge Pressure Actuator: activation-PWM rate: 100.0 %
Charge air pressure absolute position feedback-Position: 38.4 %
Turbocharger boost control: offset closed: 0 %
Sensor for engine block temperature: raw value: 79 Β°C
High press turbocharger actuator: actual uncond volt value: 1.845 V
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3416F00BB842D24EA82D500521300
VCID: 0603231FB52724A3F9-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 356194D39C417F3B20-8060
Part No SW: 6R0 937 088 B HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0321
Revision: BU046001 Serial number: 0328 277100749
Coding: 3CB02BBF08A10000002007F07C6B9CD8FF8861FF7E8E0001200000000000
Shop #: WSC 124697 483 00190
VCID: 3D718CF3A471A77BE8-8068
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU027.09.1012816
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU005.10.1016484
Coding: 48BC30
8 Faults Found:
01758 - Bulbs for Brake Lamps
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 15
Reset counter: 62
Mileage: 238160 km
Time Indication: 0
Date: 2023.05.01
Time: 19:00:24
03428 - Activation of Left Adaptive Light
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 60
Mileage: 238162 km
Time Indication: 0
Date: 2023.05.01
Time: 22:17:36
03429 - Activation of Right Adaptive Light
Fault Priority: 3
Reset counter: 60
Mileage: 238162 km
Time Indication: 0
Date: 2023.05.01
Time: 22:17:36
03301 - Response Closing Status of Drivers Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 38
Mileage: 239207 km
Time Indication: 0
Date: 2023.05.23
Time: 09:53:11
03224 - Play Protection Active
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 63
Mileage: 240895 km
Time Indication: 0
Date: 2023.06.16
Time: 14:23:00
00901 - Back-Up Lamps
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 238161 km
Time Indication: 0
Date: 2023.05.01
Time: 22:14:51
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 47
Mileage: 241306 km
Time Indication: 0
Date: 2023.06.22
Time: 22:21:39
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 205
Time Indication: 0
Component: VW10Airbag00G H09 0020
Revision: -------- Serial number: 003GX0098FDB Dataset Number: v00304886R0 0001
Coding: 003047
VCID: 4A9BD72FEDBF00C35D-801E
Serial number: 3572SRB40000CC0498BE
Serial number: 3582SRB40000CC0D02FD
Serial number: 3515RRB404T02CB8A1PD
Serial number: 3525RRB406702CBC1GK%
Part No SW: 6R0 920 861 FX HW: 6R0 920 861 FX
Component: KOMBI H05 0304
Coding: 140800
Shop #: WSC 23422 264 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 102F0547CB637A1353-8044
Address 19: CAN Gateway Labels:. 6R0-907-530-V1.clb
Part No SW: 6R0 907 530 B HW: 1K0 907 951
Component: J533 Gateway H28 0020
Revision: H28 Serial number: 240910F1002494
Coding: 7D021C00080000000002
VCID: 326BAFCFAD2F680305-8066
Component: IMMO H05 0304
Shop #: WSC 00000 000 00000
VCID: 6ADB77AF8D7FE0C37D-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11220
Shop #: WSC 00788
VCID: 2F6DA6BBEA1D45EB6A-807A
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H28 0020
Coding: 03031A64
VCID: 74E769D7D7BB2633D7-8020
Component: J367-BDM H07 0125
Serial number: 00000000002790060482
End-------------------------(Elapsed Time: 01:48)--------------------------
Fault Priority: 2
Fault Frequency: 6
Reset counter: 38
Mileage: 239207 km
Time Indication: 0
Date: 2023.05.23
Time: 09:53:11
