Hi I have a 2005 VW polo starts then immediately shuts down after a few seconds, immobiliser light is flashing on dashboard, have tried keeping key in ignition for up to 30 mins, connecting positive & negative terminals together, tried charging battery.
No fault codes seen on diagnostics reader.
Anyone else come across a similar issue?
VW 2005 polo immobiliser light flashing
- Maarten
- Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: VW 2005 immobiliser light flashing
Have you tried sparekey?
Flashing immobiliser light means no correct handshake.
No correct handshake, no running engine.
Engine dies within a second
Re: VW 2005 polo immobiliser light flashing
Hi
I have tried both keys still getting same problem yes engine starts then dies.
- Maarten
Try holding one key closer to the keyhole, whilst starting with the other.
Maybe the coil doesn't pick up the immo transponder data
Will try that thanks for the suggestion
did it worked ?
