Inner door handle actuator part number
Posted: Fri Sep 29, 2023 8:22 am
by 2226
Last night heard a small spring noise when opening driver's door from inside. Then the door actuator felt very loose. This morning I found the hooked end of the return spring sitting on the door sill.
Quick look on the ETKA I use and the actuator has no part number. Part 6 in this diagram:
Is this part sold separately or am I going to have to replace the whole trim part holding it?
The actuator still works, still returns, but much less tension on it. It's probably hanging on by friction in there.
Re: Inner door handle actuator part number
Posted: Fri Sep 29, 2023 10:03 am
by iichel
It's part of the door handle 6R0867180J or /K
by ciclo
Posted: Fri Sep 29, 2023 10:37 am
by 2226
Thanks.
Amazed a small spring breaking causes that much waste. All that plastic has to be discarded.
Will try and get one from a scrapyard.
