RCD360 Battery drain
Posted: Wed Oct 11, 2023 10:24 am
by Echo_Wick
Hey all,
Yes, this is yet another RCD360 post, sadly the ones I've seen always trash on them but never really give a solution on how to solve the issue. (Tried both No-name and Lemonshark)
I've checked many, MANY sites and tried different adapters, which visually look like they solve the issue (lights sync up with car and it turns off when ignition is off etc) but I'm still having battery drain.
When contacting the Chinese companies, they always come back with "Oh you need to change your Canbus" but as I'm aware, the units needed or been sent are only for Golf and Passat.
EDIT: While I'm working on converting my PQ system to MQB with some Jury-Rigging I have decided to run a separate power wire to the Accessory fuse which after testing for a week, works fine as a temp solution
