Hi Folks. I need an auxiliary belt for a 1.0 with power steering and no aircon. I think it should be a 6PK1070 (that is, 6 rib 1070mm long) but some ebay sellers tell me it should be a 6PK750.
Which is correct?
Thanks.
Auxilliary belt
Re: Auxilliary belt
I'm answering my own in case it helps others. After further research, the correct belt is 6PK1070 or a QH belt QBR61075 (5mm longer) will also fit.
