Dear fellow 6r owners,
last week i ordered new Brembo pads for my 6R.
https://www.bremboparts.com/asiapacific ... d/P_85_121
Pad with pins at edges : 25681
pad with pins at center : 25682
on opening the package i saw that all 4 Pads have the code 25681 were as the pdf above shows the pads as having 2 different numbers for the pads.
https://ibb.co/VCKVc7Y
So is this an error on behalf of my supplier and should i ask to replace the Pad with pins at center ? Or is it OK to install the pads with pins in center 25681 and in that case why does the Brembo Pdf show pads pins in center 25682 ?
Thank you.
Pic attached for reference.
Brakes Pad number confusion.
rana_kirti
- Drives: GT TSI
Re: Brakes Pad number confusion.
It should be perfectly fine
giannis20vt
it seems that the positions of the pins in the photo are correct. Two pads with Pins on the ends and two in the middle.
I don't know why they have the same code on them, but they seem to be different.
