I've got a leak into the drivers footwell on my 1.2 Match - 2014/ 14 plate.
I think it is the rear washer, as it only occurs if I use the rear washer and then water runs down over the top of the fuse panel onto your feet. Not great.
Anyone have a link on how to get to where the pipes must run, can it be done with lower dash removed or is it a typical VW job and I need to take the car apart. I haven't found a diagram yet through searching as to where the rear washer pipework runs. Is there a good resource to check?
SK
We have been made aware that users have been having difficulty signing up, and notification emails haven't been received. This has now been resolved and there should be no problems for anyone going forward. Our apologies - last minute firewall upgrade with a missing rule!
The UK-Polos.NET Team
