Model identification
Posted: Tue May 14, 2024 6:36 am
by Polo2323
Hi all. Sorry for this basic post but I need some help
I have a 65 (2015)
plate polo 1.2tsi blue motion tech
Is this a 6c? Also how do I tell if it’s a timing chain it belt?
Re: Model identification
Posted: Tue May 14, 2024 6:56 am
by ciclo
6R vs 6C images:
https://blog.astina.dk/polo-6r-6c-facelift.html
1.2 TSI 6C ... Timing belt.
Posted: Tue May 14, 2024 9:58 am
by Polo2323
So is mine a 6R or 6c I thinks it’s 88bhp is that correct?
Also anyone know when you need a cam belt change? It’s currently on 47,000
Posted: Wed May 15, 2024 11:42 pm
by RUM4MO
As said already, it is a 6C Polo, but if you want to be sue about the engine, look under the bonnet, if it is a belt driven cam shaft engine, the cam belt cover will be black plastic and there will be an engine designation label on it CJZC which is the 90PS version.
If you want another way to check which Polo model type you have, again look into the engine compartment, the turbo charger and exhaust should be on the side of the engine nearest the cabin if it has a belt driven cam shaft - in other words, if you look down the front of the engine, ie the side nearest the bonnet catch/headlights, you should not see a turbo charger or exhaust down there, just an air charge cooler.
Posted: Thu May 16, 2024 8:44 am
by iichel
if you feel like sharing a picture, we'll be happy to have a look with you
