Morning .
Got a 1.2tdi non starter . No reading from the camshaft sensor . Replaced the sensor still the same . Also got a code showing a problem with an open sensor . Playing with wiring will start occasionally. Iam after a pin diagram for the ecu to check the wiring . Thanks
1.2tdi non start camshaft sensor fault
Re: 1.2tdi non start camshaft sensor fault
You can get a wiring diagram on Erwin for a few euros
