Polo 2022 - when auto is switched for wipers it makes a noise
Posted: Wed Aug 28, 2024 6:43 pm
by Cheese101
https://player.vimeo.com/video/1003727941?h=41705efe43
When I have my wipers set to auto and they wipe I hear this click noise. Is this normal? I have sat in other cars and I don’t hear any noises with auto wipers.
Re: Polo 2022 - when auto is switched for wipers it makes a noise
Posted: Wed Aug 28, 2024 6:56 pm
by Dark_cze
Yes it is normal, there is relay switching power to wiper motor.
I am pretty sure it should do it on every speed not just auto.
Posted: Wed Aug 28, 2024 8:54 pm
by Maarten
Only on interval should you hear the clicking.
And only when they operatie
On continious wiping the relais is on so no clicking.
Posted: Sat Aug 31, 2024 6:49 am
by Dark_cze
Maarten wrote: Wed Aug 28, 2024 8:54 pm
Well on continues wiping it should click once you switch them on and once you turn them off
Posted: Sat Aug 31, 2024 5:18 pm
by Maarten
That's true
Posted: Sun Sep 15, 2024 12:30 pm
by Ian T
Mine does the same.... only noticed it the other day after nearly two months of ownership
Posted: Thu Oct 03, 2024 10:15 am
by Polo 2610
The windshield wipers on the VW Polo GTI are very noisy, any solution?
Posted: Thu Oct 03, 2024 1:02 pm
by Maarten
Buy a good brand i.e. Bosch or Valeo, replace yearly
Posted: Thu Oct 03, 2024 3:12 pm
by SRGTD
Polo 2610 wrote: Thu Oct 03, 2024 10:15 am
Presumably you mean the actual wiper blades on the screen while they’re wiping are noisy, rather than the noise being caused by another part of the wiper system (e.g. worn bearing in the wiper motor or noisy wiper linkage).
Assuming you are referring to the wiper blades, then as @Maarten has suggested, replacing the blades would be the solution. I fitted Bosch Aerotwin wiper blades to my GTI+ and they were very good; quiet and smooth in operation.
Posted: Thu Oct 03, 2024 5:37 pm
by Harrihealey02
I've owned two Polos, and both had incredibly loud window wipers from the start. After enduring the constant juddering for three months, I switched to Valeo Silenco wipers, which are blissfully silent—exactly as they should be. I’ve never experienced new wipers that juddered so much. They were fitted with Bosch Aerotwin wipers, but I think the rubber compound was too brittle, causing them to jump on the windscreen. The Valeo Silencos, true to their name, are completely silent!
