Monday,13,January,2025,19:01:15:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
Dealer/Shop Name: GermandnatoAdi
VIN: MEXJ19604LT057986 License Plate: UKPOLOS
Mileage: 64340km-39979mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 65
VIN: MEXJ19604LT0XXXX Mileage: 64340km-39979miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D87C9A91D1200B2F45-8038
VINID: 755A1A04918011C9001472481803BBEAEB
Readiness: 0110 0100
Part No SW: 0AM 300 043 C HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2601
Revision: 00005008 Serial number: CU501906266575
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2B0307B1EF06CE82AA1-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Serial number: --------------
Coding: 62DD2463422803C7461D24714257C0800908
VCID: 0059801D3A80FDDA2F3-8054
Serial number: 07071913470686
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FEE540748B2A5DF-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DF4519718A34D260D-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 320180219
Coding: 3AB82BF848A30000133806307CEB9E9002C0640F608D31412304000B0000
Shop #: WSC 12345 123 61029
VCID: 2C0104ADE608C9BAA3B-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 270722 05 52 0106
Coding: 066800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848190716085938
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849190711213513
Coding: 040000
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 31G 959 442 HW: 31G 959 442
Serial number: 0401812433500024CX3J
Coding: 250000
Subsystem 7 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13102728190711175909
Subsystem 8 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729190711052611
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 19531723201065 Dataset Number: 160039v____ 0010
Coding: 0001155011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 372B2BC12FCE7A62DE9-8062
1 Fault Found:
12718592 - Databus
U1121 00 [00001001] - Missing Message
[Steuerger t f r Lenks ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZAAYABLK Dataset Number: V03935303ZE 0001
Coding: 880000000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 41DF4519710A34D260D-8014
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
Shop #: WSC 00046 123 12345
VCID: 47CB5B015F2E0AE2AE9-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002307
VCID: 6889B8BD3270259A873-803C
Component: IMMO H05 0805
VCID: 6A8DC2B52CFC178A917-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: V03935277QZ 0001
Coding: 0001000000000000
Shop #: WSC 12345 123 12345
ROD: EV_SteerAssisNSK_014_VW12.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 L HW: 5K7 035 200 D
Component: MU-S--ER H22 0480
Serial number: VWZAZ2R8032189 Dataset Number: 5K7CV1v__A_ 0001
Coding: 0262000EFF00000011110001001828001F0103D60020010006
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 2D0709A9DD92C0B2B45-8078
4 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Fault Priority: 4
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Voltage terminal 30: 11.8 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: ERROR
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
U1101 00 [00001001] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Voltage terminal 30: 12.0 V
0001 - Antenna 1 for Radio
B1119 13 [00001001] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Voltage terminal 30: 11.9 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 0 dB V
0003 - Antenna 2 for radio
B111A 13 [00001001] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 0 dB V
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 30000000451195 Dataset Number: rdkseditor 0016
ROD: EV_RDKBERU30_005.rod
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.2V)-----------
