Cheap wheels to fit Polo 9n
Posted: Mon Feb 10, 2025 7:08 pm
by Bikergonebald
My daughter has a 2004 Polo 1.2 Twist with 14" alloys. She thought she had a puncture but the garage advised it is corrosion around the wheel bead causing it and the other wheels are going the same way.
She can't be without the car while i fix the wheels so i'm looking for a cheap set to replace them. I don't see the point changing them with a set of the same age so i'm looking at slightly newer cars.
I expect the wheels from a 9n3 model would fit but what about later cars?
I assume that if the wheels from later polos fit then so would those from Ibiza's and Fabia's?
I don't want anything bigger than a 15".
If you have a set to sell I'm in Worcestershire.
Thanks.
Re: Cheap wheels to fit Polo 9n
Posted: Mon Feb 10, 2025 7:42 pm
by Maarten
5x100 should fit
Rims from skoda Fabia, seat Ibiza, Audi (A2?) and all model polo from 2002 and up will fit
Larger models like golf, octavia, A4 etc are 5x112 and will not fit
