We have been made aware that users have been having difficulty signing up, and notification emails haven't been received. This has now been resolved and there should be no problems for anyone going forward. Our apologies - last minute firewall upgrade with a missing rule!
The UK-Polos.NET Team
6R 1.2 TSI CBZB - Voltage regulator upgrade
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Hi to all,
my car is a 2010 6R 1.2 TSI CBZB MT with 225.000km on the IC.
Recently I've been monitoring charge voltage output with OBD11/VCDS and with a multimeter connected on the battery's terminals and on the cigarette's lighter port.
I'm not sure if the values I'm reading are absolutely fine or the anticipation of a component's failure (alternator or voltage regulator), but here they are:
  • As soon as engine is started and cold, voltage is 14,1-14,3V. The colder ambient temperature is and the higher starting charge voltage is.
    After around 10mins, it drops at 13,8-13,9V.
    After 30mins / 1 hour of city traffic, it drops at 13,5-13,7V.
    At this point, if I turn on cabin's fan to max speed, ac compressor and rear window's defroster, voltage drops at 13,2-13,4V.
To me these values look a bit low, especially the last one.
Last sunday I checked and cleaned all the battery terminals positive and negative wires and the engine-chassis ground wires. After that, at first it looked like charge voltage raised more in the 14V area with warm engine and accessories turned ON. But after a few days, I noticed the situation got back down the same valures I wrote above.
What do you think?
Is there something else I should check?
I write the long-coding of my BCM, just in case any of you want to check if there is a bit incorrectly coded which might negatively affect charge voltage output:
3CB02BB808210000003800003D2B9CD00040670F60020000200000000000
If everything look absolutely fine and you think there's no problem to investigate, here comes the second answer.
Is there a way to increase charge voltage output?
I'd like to increase it of an amount of 0,4-0,5V in all conditions.
I've been thinking if it would be possible to swap my voltage regulator (06F 903 803 B) with another one with an higher voltage set-point, but I'm not sure if there is one compatible with my alternator (03F 903 023 D).
For example, I found on ETKA a voltage regulator from big engines installed on Polo and A1 (part n. 07K 903 803), it looks aesthetically identical to mine, but how can I know if it has an higher voltage set-point and if it's plug&play?
06F 903 803 B:
07K 903 803:
If someone knows more about this, any help would very much appreciated. :)
