Lumpy running
Posted: Mon Oct 11, 2004 5:11 pm
by GroovyCarrot
I fitted a new carb yesterday (well, an old carb that I know nothing about but had sitting in the shed) as my old one was knackered.. this one runs fine most of the time, doesn't cut out in the cold like the last one did, and seems to be a bit more economical than the last one (although I haven't actually had a chance to work out the mpg yet), there's just one problem, just occasionally when I'm accellerating at a low speed at low revs (ie turning into a junction in 2nd gear), the engine starts running a bit lumpy. The tone of the engine doesn't change, but the power comes and goes in lumps. Also, when I'm accellerating, there seems to be less power than usual until I hit about 2,200 rpm, then it pulls just as it normally would.
Can anyone suggest why it's doing this? Could it just be that the carb's been sat in a shed for a few months and something's a bit sticky? I've flushed it with redex, but I don't know enough about carbs to really know what could be causing this..
Posted: Mon Oct 11, 2004 5:33 pm
by Gareth_GT_Hatch
Did you replace the carb/inlet manifold gasket or rubber seal or whatever it is?
Posted: Mon Oct 11, 2004 5:43 pm
by GroovyCarrot
The rubber block that the carb sits on, or another seal? I didn't change the rubber thing.. but then I didn't change it last time I took the carb off and it seemed alright, it's in good condition anyway. If you mean another seal.. um.. nope :? Fraid not, didn't know there was one. Might just be the problem I guess..
Posted: Mon Oct 11, 2004 6:53 pm
by mk2keel
Have you run loadsa petrol injector/carb cleaner through it, you normally have to shove it in the tank with so many litres of petrol dunno if that would help.
Also it sounds like somethings a little sticky there, have a mate check it over if you can see if they can find anything.
Posted: Mon Oct 11, 2004 7:58 pm
by GroovyCarrot
Yeah, I did a carb flush with redex.. poured about 1/4 bottle in the top and had some fun covering the village in white smoke :) I've also got a bit in the petrol tank, I'll stick some more in though.
I'd have a mate take a look at it, but the only person I know who has a clue about cars is my mechanic, and he charges £35/hour, which is about £35 more than I can spend at the moment :? Don't suppose spraying wd40 in the top is likely to make a difference? :)
Posted: Thu Oct 21, 2004 4:18 pm
by bstardchild
Stop messing about and buy this
http://www.tigerstyle.co.uk/poloforum/v ... php?t=8383
Exactly what the doctor ordered :lol:
