Hissing A/C Now no longer working
Posted: Fri Jun 19, 2026 1:52 pm
by jjscruff
Hot day and as i pulled in to park at home and turned the engine off, the ventilation system lett out a hissing sigh.
Now its unable to produce cold air.
Could just need an AC gas top up? I don't think its ever been done (2012 car)
Or does this point to a leaking system?
It was functioning perfectly fine before the hissing noise
Re: Hissing A/C Now no longer working
Posted: Fri Jun 19, 2026 3:29 pm
by RUM4MO
Best plan is to hand it into a proper AC place for checking which will mean recovering any R134 left in the system - and weigh it, apply a vacuum to dry the system and at the same time check that it is leak free enough to get recharged/refilled.
All these mobile Car AC systems do lose a small amount of their AC gas charge - that is because they have "rubber" flexible pipes and similar O-ring seals, so eventually having it ending up being "short of gas" during a hot period of weather is not too surprising at its age.
Posted: Sat Jun 20, 2026 10:30 am
by jjscruff
thanks for your reply.what should i look for in finding a proper AC place?
Posted: Sat Jun 20, 2026 7:35 pm
by RUM4MO
Maybe even try a local ATS if you have them nearby - and check online for any discount codes.
Posted: Tue Jun 23, 2026 8:51 am
by callumhind
The hissing is characteristic of a system that is low on refrigerant. Has it been hissing for a while, or has it very suddenly started happening?
If it’s been going on for a while, I would hedge my bets at it just needing a recharge (make sure to get a proper garage to do this as they will need to pull a vacuum on to test for any major leaks and to also dry out the system of any moisture). If it’s come on very suddenly, it could be a leak, but I would personally look at a recharge as a first point of action.
