UK-POLOS.NET - THE VW Polo Forum • Engine Warning light - any ideas?
Posted: Sun Jun 21, 2026 3:17 pm
by Polonut
Hiya Guys
2020 Polo Match 55000. Today (hot day) engine warning light on!
Car running without any misfires, or any noises.
All levels correct.
Got home, and lifted bonnet - no visual problems - heard what sounds like a very quiet electric motor running (very low noise) rad fan not turrning.
Any immediate ideas come to mind - . When car cools down will check the fan connection. BUT will fan failure be described/included as a legitimate cause for engine light
Ideas welcomed
C
Re: Engine Warning light - any ideas?
Posted: Sun Jun 21, 2026 8:49 pm
by iichel
Read error codes via OBD
Posted: Tue Jun 23, 2026 11:26 pm
by CarbonChaos
Anything else is guesswork
Posted: Wed Jun 24, 2026 11:44 am
by J+silva
OBD is the first step if you can't see anything visually.
Posted: Sat Jun 27, 2026 11:17 am
by Polonut
As you say OBD is the only way!
when connected - full search revealed the air intake purge sensor at fault. Disconnected, then reconnected - fault then cleared since no re occurace.
Must but one myself - any recommendations for simple but inexpensive unit?
C
