Gearbox Mount
Posted: Sat Sep 12, 2026 1:32 pm
by Rowlers
Hello..
I'm trying to fix a clunk on my son's polo 1.2tsi manual 2016. 90k miles
Clunk/knock when up shifting.
You can prevent the clunk by easing right off the accelerator and smoothly coming up with the clutch, but not normal driving, every upshift is a clunk.
I've put an new dog bone in it - the old one was very soft. This has helped, bit not fixed it..
So I've looked at the gearbox mount and it looks like it has a lot of front/back movement:
https://youtube.com/shorts/-5uQTiVFfqU?feature=share
Is this normal or excessive, not a lot of force was required to generate this movement.
Any ideas?
Re: Gearbox Mount
Posted: Sat Sep 12, 2026 2:19 pm
by 2226
Looks like too much to me.
I'd replace that. Fairly quick job to do (unless you cross thread the bolt like I did and have to quickly find the tap kit to re-tap it
They will move just by hand, but that looks like too much.
Replaced mine well over a year ago with a Febi unit. Has started feeling soft again lately, but I have no changed the dogbone yet.
All these mounts are super soft as VW tries to manage NVH on such a small platform.
Re: Gearbox Mount
Posted: Sat Sep 12, 2026 2:45 pm
by Rowlers
Brilliant thanks for the reply. confirms my suspicions...
Re: Gearbox Mount
Posted: Sun Sep 13, 2026 10:19 am
by RUM4MO
It was the gearbox mounting that caused that on my wife's August 2015 VW Polo 1.2TSI 110PS 6MT.
For some reason, VW Group used the "petrol" engine version on all the petrol engines even the turbo charged ones - and that caused many people to complain, then some time later, I think, they started fitting the TDI version to all the turbo charged engines petrol and diesel - now after maybe 9 years, I still can't rock the engine fore-aft very much, so that sorted that out!
I can hand over the part numbers later - just about to go out!
Re: Gearbox Mount
Posted: Sun Sep 13, 2026 2:31 pm
by 2226
@RUM4MO Could you confirm the part number on that one?
6RF199851C?
That is the diesel one I am aiming to fit.
Re: Gearbox Mount
Posted: Sun Sep 13, 2026 9:36 pm
by RUM4MO
I can't find any reference to that number for 6C Polo, the first group of letters/numbers looks odd.
It was 6Q0 199 851 AS that is still listed for 1.2TSI both power outputs for the dog bone, the gearbox mounting was 6Q0 199 555 AR - and you can check the number punched/stamped into the metalwork of the mounting fitted to the car now, that was replaced by 6Q0 199 555 AS which at that time was the "TDI only" version - now TDI version has changed again.
One bodge was to buy the TDI dog bone - which was the wrong "shape" overall, press out its bonded bush, then fit that into the dog bone of the petrol engined version - ie end up with a sort of hybrid for want of a better description.
First Edit:- The correct "shape" dog bone mount for all the 1.4TDI engines now is 6C0 199 851 J .
Second Edit:- that VW Group part number, 6RF 199 851 C, does appear in the internet, but not a form of "numbering" that the official web cat uses for these cars, strange!
Third Edit:- or maybe the bodge was to remove the complete alloy arm with its bonded bushes intact, and fit that into the correct black metal bracket part of the dog bone mount.
Re: Gearbox Mount
Posted: Mon Sep 14, 2026 7:34 am
by 2226
851AS sounds familiar. Might be the one I have.
From what I've seen these all look the same with the difference in the steel mounting bracket and bushing.
Swapped between the 9N (or rather the Polo Vivo) and the 6R/6C.
The 6RF199851C is listed for the Vivo automatic (1.4/1.6 petrol), but also listed for earlier manuals for 9N/6R/6C. Also against a earlier 1.6TDI in the Polo saloon. Again pointing that these things all seem the same with probably just difference in rubber durometer and steel bracket.
Of all of them the 851C has a very different looking rubber mount installation.
My local aftermarket shop Borsehung version in stock, so I might at some point just pop around and compare it against the length of my VibraTechnics mount (I don't have spare OE part).
VW is going to continue swapping these part numbers until there's no 9N/6R/6C left to swap to.
Just give a final solution because this flopping drivetrain thing is annoying.
Re: Gearbox Mount
Posted: Mon Sep 21, 2026 4:15 pm
by Rowlers
Just changed the gearbox mount (bit of a tight squeeze to get at the 16mms!!) and while its made it a bit better the clunk it still there.
So, I'm at a bit of a loss as to what else it could be.
Its just, today, passed its MOT with no advisories so there is no bushes etc with play..
Any ideas what else it could be?
Re: Gearbox Mount
Posted: Mon Sep 21, 2026 9:29 pm
by 2226
At this point... just call it a feature and move on with life.
Could you record the noise you hear?
Maybe park it up, then have someone engage the clutch slightly while you check the engine bay. See what rocks and what knocks.
How are your control arm bushings looking?
Re: Gearbox Mount
Posted: Tue Sep 22, 2026 12:34 pm
by Rowlers
2226 wrote: Mon Sep 21, 2026 9:29 pm
It only does it when driving so it will be difficult to record. Bushings are surely good after passing its MOT. I can't get it to make the nouse while stationary.
Yeah, I'm likely going to just leave it. I don't think my Son is too bothered!
Re: Gearbox Mount
Posted: Sun Sep 27, 2026 9:37 am
by CarbonChaos
This is a common misconception about the M.O.T test ,it passed so everything must be 100% good , not the case . The M.O.T test is only looking at minimum safety standards for road worthiness , ie should this vehicle be operated on the road safely
