Rear Lights Not Working after LED
Posted: Wed Nov 04, 2026 7:17 pm
by s0234
So basically, one of my brake lights went out and I thought it would be a great opportunity to upgrade them instead. I bought a pair of red LED bulbs and installed them. The good news is, I have brake lights again. Bad news is, the main rear light/driving light, itself doesn’t seem to work for some reason. Everything else works fine, the brakes, indicators, fog light, reverse light, everything apart from the driving lights. Anyone knows why this may be or any fix for it? I can’t drive it at night because nobody can see me, I’ve been using my rear fog light but that can only do so much and can be distracting for some other drivers behind me.
I’ve already checked fuses (18-22) and they all seem to be intact.
Re: Rear Lights Not Working after LED
Posted: Thu Nov 05, 2026 2:52 am
by ciclo
Install filament/conventional/standard-type brake bulbs to see if the new LED bulbs are interfering 'in any way' with the side/position/parking lights (driving lights).
I don't think the new LED bulbs offer any improvement in brake light performance compared to conventional/standard bulbs. The 6R/6C tail light assemblies have a very specific design intended to function correctly (light output) in conjunction with filament/standard bulbs.
Tested/verified:
In the tail light assemblies of 6R/6C models, using LED bulbs is only a 'viable improvement' for the reversing light and turn signals, but/however, this requires very specific coding within a particular version of the BCM 'Max' module.
Alternatively, provide a diagnostic report/scan (fault/s ?).
Are there any warning light on the instrument cluster?
Posted: Tue Nov 17, 2026 8:18 pm
by s0234
ciclo wrote: Thu Nov 05, 2026 2:52 am Install filament/conventional/standard-type brake bulbs to see if the new LED bulbs are interfering 'in any way' with the side/position/parking lights (driving lights).
Tested/verified:
Turns out the T10 bulb blew out, it's definitely due to the LED bulbs but I'm not sure why. I'm thinking since I need to replace the T10 anyway now, just replace it with LED ones
Posted: Wed Nov 18, 2026 12:01 am
by ciclo
It is highly likely that the very act of removing the taillight assembly caused the filament in the T10 bulb—already worn from use—to finally break.
As I mentioned, I do not recommend LED bulbs for 6R/6C taillights—especially for the T10 position/side lights—as the light output is not uniform, which will result in a distorted or poorly defined appearance for the taillight.
I also don’t believe the BCM (Body Control Module) in your 6R can "properly" manage LED bulbs, even if no error codes appear or the bulbs are "CAN bus" compatible.
Perhaps your 6R’s BCM could better handle T10 W16W bulbs instead of the factory-standard T10 W5W ones; this would provide the best possible light output for your 6R/6C taillights. I've had this setup on my 6R for many years, maybe 10, with 6C taillights, and it's definitely the best for these lights.
