Hi all,
We are looking to upgrade my son’s radio in his 2014 Polo to one that has Apple CarPlay. He currently has a VW unit 6C0 919 603 installed with a VW Composition Media system in the glove box. I was wondering if anyone can recommend a good, not too expensive replacement radio that he could get please?? I have attached pictures of the unit, media system and connections on the back. Thanks in advance.
Apple CarPlay radio upgrade
Mikeydh
- Drives: 1.0 TSI blue motion
- IMG_9622.jpeg (256.62 KiB) Viewed 1610 times
- IMG_9623.jpeg (74.43 KiB) Viewed 1610 times
- IMG_9624.jpeg (229.82 KiB) Viewed 1610 times
Re: Apple CarPlay radio upgrade
Hi Mikeydh, welcome to the forum!
You have a 2014 Polo 6C fitted with the factory MIB1 Composition Media system (screen 6C0 919 603 + main unit in the glovebox).
Strongly advise keeping the original VW system rather than replacing the head unit:
-Why not an OEM MIB2 swap? Your 2014 MIB1 unit doesn't support factory App-Connect/CarPlay, and upgrading to a newer OEM MIB2 unit is expensive because it requires online Component Protection (CP) removal, coding, and a new USB port.
-Why not a cheap aftermarket/Android head unit? On the Polo 6C, the CAR menu controls key vehicle settings (TPMS reset, lighting, wipers, trip data). Replacing the factory unit means losing or breaking those OEM functions.
The Best & Most Cost-Effective Solution: An MIB1 CarPlay Interface Box (MMI Box)
Instead of replacing the radio, fit a plug-and-play CarPlay/Android Auto retrofit interface box designed for VW MIB1/MIB2 systems (with the separate glovebox unit).
-How it works: It sits hidden behind the glovebox using a plug-and-play Quadlock Y-harness and intercepts the blue LVDS video cable (shown in your 3rd photo).
-OEM Integration: You keep the factory screen, steering wheel controls, factory Bluetooth/mic, and the CAR menu. Simply hold down the MENU (or MEDIA) button for 2 seconds to switch the original screen into Wireless Apple CarPlay (or Android Auto).
Options:
-Brands like Andream, RoadTop, or CarABC (widely available on eBay/AliExpress for VW MIB1/MIB2).
-Kits like the Integrated Automotive IMI-1000 if you want local UK warranty and instructions.
Just make sure the car has an AUX port enabled/fitted, which nearly all UK 6C SE models do, as these interface boxes feed CarPlay audio into the factory system via the Quadlock AUX pins.
Options:
