Gearstick not centring back to neutral
kasialis721
- Drives: 2010 VW Polo S
Having an issue where the gearstick is not going back to neutral. It moves fine up and down (e.g. switching from 1st to 2nd, 3rd to 4th etc) but it does not centre moving side to side. I can't see any missing bushings or anything, I'll attach a picture of it, but I noticed the issue when I was trying to go into reverse: I was unable to get the stick into reverse, as I could not find the centre where neutral was meant to be. Happened all of a sudden, and happens both with the engine turned off and on. I think it could be an issue with that spring on the side, return spring?
- IMG_4644.jpeg (1.92 MiB) Viewed 99 times
- IMG_4645.jpeg (2.3 MiB) Viewed 99 times
- IMG_4643.jpeg (2.14 MiB) Viewed 99 times
